10-17-2014 11:57 AM
Hi folks,
I have a 1Ds MKIII and am a proud owner of a brand new EF70-200L ISII lens. I purchased it from an authorized big box retailer so I am not worried that it is grey market.
I noticed the lens body, when connected to the 1Ds camera body, has a little/very slight movement at the reticule. I believe the technical word of the lens part in question is the "rubber ring" contact of the lens body. See attached picture of the area in question.
When I say slight movement, I mean maybe 0.5mm of play (when try to move the lens body by hand) while it is fully connected/locked into the 1Ds body.
Just for comparison, my 24-70mm L lens body also has slight movement when fully connected/locked into the 1Ds body but its movement is maybe 0.25mm of play.
So my question is: do you also experience this type of connectivity movement with your lens-to-camera body? Or is this abnormal. I have a feeling it's very normal, it's just that it is a little more noticeable with my 70-200mm versus my 24-70mm.
Should I send it back to the retailer or send it in to Canon using the warranty?
10-18-2014 11:33 AM
10-18-2014 05:44 PM
@ScottyP wrote:
I have read about the slight loose fit issue with this lens on a 5D3. I have this lens and it fits very tightly on my 6D. I have never heard of it affecting image quality, only people speculating that it could hypothetically impair weather sealing. I don't think that there would be any great market products sold through a big box dealer, and I also don't think there's any difference whatsoever between gray market and the USA version of a lens when it comes to the fit and finish and build quality. The only differences in the warranty
There is no such thing as a fake knock off lens. Grey market is only about where and how your warranty can be used.
Isn't it actually about whether, not where or how, the warranty can be used? It's my understanding that the warranty has to be used in the country where the lens was sold, but a grey market lens is a lens without a country. I believe that the grey market lenses sold by B&H, for example, are backed by B&H, not by Canon.
FWIW, I've used my 70-200 on my 5D3, and I don't recall there being any noticeable play in the mount. I won't have a chance to verify that this evening, but I'll try to do it tomorrow.
10-18-2014 10:25 PM
10-19-2014 10:18 AM
I believe it to be "normal". But without seeing it for myself I will not say 100% but I will say 90%.
Your fantastic 1Ds Mk III has some years and ware on it by now. And you must realize there is a tolerence limit in manufacturing. You might have recieved one that is at the upper limit of tolerence. I am confidnet it is fine, however.
Try it and see ! WOW, 1Ds Mk III and the 70-200mm f2.8 is the best fo the best, as good as it gets.
