New 50mm 1:1.8 lens won’t work on M50
naledi
If anyone knows what to do, please respond because I don’t know much about cameras.
I bought the 50mm lens to improve my content (I also purchased the Viltrox adapter) for my M50. At first the lens & camera was on MF and refused to go on Autofocus, I then realized that i couldn’t even capture a picture or record a video.
I then tried to change my settings to AF ( I was going through different settings and disabling anything that had ‘MF’ and enabling anything that had ‘AF’ but now my screen is completely blank.
please help.
7 REPLIES 7
Waddizzle
It could be an issue with the adapter.  You might also need to go into the men system and enable “Release shutter without lens”.
jrhoffman75
Welcome to the forum.
Is it a Canon EF 50mm f/1.8 STM lens?
Turns out I didn’t connect the lens correctly🥲
Thank You!
Hi!
so I disassembled the lens from the adapter & camera, reassembled it again and it finally worked.
Thank You!
f8fully
I just bought same lens for my Mark II, do I need an adapter for it to work? Also what adapter should I use?
jrhoffman75
You need the Canon EF-M adapter. Only get the true Canon product. EF and EF-S lens work great.
You usually can't go wrong with genuine Canon products, but many of us have used the Viltrox adapter with excellent results and saved a lot of money.
Kevin Rahe
EOS M50 Mark II
