05-01-2014 10:31 PM
My canon 50mm 1.4 lens is stuck at f/1.4. The image is identical from 1.4 all the way to f/22. I don't know why this is happening. Any ideas?
05-02-2014 06:15 AM
05-02-2014 08:56 AM
"My canon 50mm 1.4 lens is stuck at f/1.4."
You have it set to Av mode. Switch back to the green square.
05-02-2014 12:31 PM
05-02-2014 04:41 PM
Sorry for not giving enough info. I first tested the lens on a t3i when I discovered the problem. I then switched to a 5Dmkii to see if it was the camera but I had the same issue. I was in video mode on the t3i and manual on the 5D. It seems like the lens won't move from f/1.4 even thought the cameras read at different f stops.
05-05-2014 12:06 PM
@ebiggs1 wrote:"My canon 50mm 1.4 lens is stuck at f/1.4."
Why would you use the green square if you were trying to get a different aperture? Av is exactly the mode I'd use - or manual.
05-05-2014 12:23 PM
@ragercker901 wrote:Sorry for not giving enough info. I first tested the lens on a t3i when I discovered the problem. I then switched to a 5Dmkii to see if it was the camera but I had the same issue. I was in video mode on the t3i and manual on the 5D. It seems like the lens won't move from f/1.4 even thought the cameras read at different f stops.
If you begin recording at a different aperture does it look like it's shot at that aperture or still 1.4? If you're on manual and just change the aperture then does the exposure dim? Can you change the aperture for stills? Sorry, don't know much about video, but that's where I'd start my trouble shooting.
05-05-2014 12:25 PM - edited 05-05-2014 12:25 PM
"Why would you use the green square ..."
By mistake! ![]()
05-05-2014 01:05 PM
No matter what I do the aperture doesn't change. I've shot with the lens/camera for over 3 years and this is the first time I've had a problem like this.
05-05-2014 03:39 PM
I think yiu have answered your own question, it is broke. ![]()
