Mount Adapter EF-EOS R Compatibility with EF 70-200mm F2.8
sle2017
I recently purchased a mirrorless camera after using DSLR.  I got an EF-EOS R adapter.  I am looking into purchasing an EF 70-200mm f/2.8 lens, but want to make sure it will mount to the adapter before I make that decision. Does anyone know if it will mount? TIA!!
5 REPLIES 5
deebatman316
The EF or EF-S- RF Mount adapter works with ALL Canon EF and EF-S Mount lenses. But the EF 70-200mm F/2.8L series lenses are great. I would recommend using the native RF lenses. So a mount adapter isn't needed.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
rs-eos
As Demetrius mentioned, yes.  I would add though that hopefully you got a Canon brand adapter.
Ricky
governtendon
All Canon lenses with an EF or EF-S mount may be used with the RF Mount adaptor. However, excellent optics can be found in the EF 70–200mm F2.8L range. To get the best results, go with the native RF lenses. Therefore, a mount adapter is unnecessary.
Peter
EF 70-200/2.8L IS USM II and III will give you the fastest burst rate with R5/R6 in mechanical shutter mode.
The older 70-200/2.8L lenses will slow down the burst rate.
ebiggs1
"I recently purchased a mirrorless camera after using DSLR.  I got an EF-EOS R adapter.  I am looking into purchasing an EF 70-200mm f/2.8 lens,..."
Why? Why in the world would you buy a new R series mirrorless camera and then buy an old tech EF lens. Makes no sense.
EOS 1DX and many lenses.
