Lens recommendations for outdoor sports
Rkiger
Hello I am looking to upgrade my lense for the EOS Rebel T3 I do not want to upgrade my camera as it works just fine I would like to find a new lense for outdoor sports such as frisbee golf and indoor spots such as ice hockey what is the best lense for these things?
3 ACCEPTED SOLUTIONS
MPBACK
Rising Star
Rising Star
Canon still offers several telephoto zoom lenses that would be a good fit for the CanonRebel T3.  They are 70-300mm range.  These lenses are reasonably priced.  Canon also makes more expensive L line lenses that would work well also.  If you are looking for longer range zoom lenses greater than 300 mm, Canon also offers those, however do get expensive.  Other than Canon, Lens companies such as Tamron and Sigma also make lenses to fit Canon EF-S and EF mounts, both of which will work on the T3.
Yes but you may come across compatibility issues. Just because it says compatible with Canon EF Mount doesn't mean its 100% compatible. Some camera body and lens combos don't work well together. Especially when there's an age gape between when the camera body and lens were released.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
ebiggs1
No lens mentioned so far is as good as the Tamron SP 70-200mm F/2.8 Di VC G2. It is simply amazing, It would work as well as anything you can buy for indoor sports only being surpassed by the Canon EF 70-200mm f/2.8L IS III USM Lens which is the gold standard.
EOS 1DX and many lenses.
11 REPLIES 11
deebatman316
What is your budget to spend on a new lens and is low light a concern of yours. Since ice hockey was mentioned which is usually played indoors.
-Demetrius
 I do not have a set budget  as I looking to as for the lense anyone will suggest as a gift. But most of my problems are with lighting as most of the rinks do not have proper lighting which takes a lot of time in editing.
MPBACK
Rising Star
Rising Star
Budget is a key thing before we can suggest a lens. Large aperture lenses come with a hefty price tag but greatly help the camera's AF system and lock focus faster. Since these lenses use a faster and more accurate AF motor than cheaper lenses do. They also use a constant aperture throughout the entire zoom instead of a variable aperture. With a variable aperture lens the more you zoom in the less light enters the camera. Variable aperture DSLR lenses usually have an aperture as slow as F/5.6. They won't be any slower than that because there won't be enough light to focus. Also most cameras won't focus with an aperture smaller than F/5.6. Some professional grade DSLR cameras will focus down to F/8.
-Demetrius
  These are the lenses I am using now at my event they have been working great
I also was looking at the
would this be a good lense?
The EF 24-105mm F/4IS USM lens is a great professional grade standard zoom lens for Full Frame cameras. The EF 28-135mm F/3.5-5.6 IS USM was mainly used as a kit lens for late EOS film bodies and some early EOS Digital Full Frame and APS-C cameras. I used to own a copy and it was a great lens except it didn't perform well in low light. You will need a longer lens and a wider aperture lens to achieve what you need for sports.
-Demetrius
-Demetrius
OK, I also use the EF 24-105L and has been a part of my kit for over 10 years.
