05-21-2023 06:29 PM
I just purchased a 750D with the standard lens kit. I have never had a DLSR before, so I am very exited to get started making film with this one.
I am only going to use it for filming in 1080P 24/25fps - shutterspeed(50) for making short films on a hobby-level, using a tripod and a hand stabilizer.
I have been testing it out a bit, in low light conditions and can already see it struggles a bit.
What inexpense lens would you recommend for my specific use-case? I am also working with lighting for my shots to help out the scenes.
I have also ordered a variable ND filter for shots during daytime, to prevent going higher on the ISO.
05-21-2023 06:34 PM
Do you have a budget to spend on a lens. A good lens with a constant fast aperture doesn't come very cheap. Where exactly are you living. I noticed you said 25 fps or 50 fps which is an EU or non-US (PAL) video system frame rate. You also said EOS 750D which is was sold in North America as the Digital Rebel T6i.
05-21-2023 10:44 PM
Unless you can add light to the scene, you’d only have two options: raise ISO or have a wider aperture.
if you can get by with a prime lens, then a 50mm f/1.8 could work well. Especially if your current lens say could only go to f/3.5.
Do note thought that using a wide aperture will reduce depth of field. And sometimes it can end up being very narrow which can be challenging when filming.
Unfortunately, if f/1.8 wouldn’t be enough, you’d need to invest in better gear. That is gear with sensors with larger sensor sites along with better ISO performance. Potentially coupled with even wider apertures such as f/1.2
