04-26-2022 06:33 PM
04-26-2022 11:38 PM
What kinds of objects were you trying to focus on, and how far away were they?
Is it always the same objects with different cameras?
04-27-2022 07:18 AM
people 15 to 50 ft away. I can put on my 24-70 Lens and it works fine.
04-27-2022 07:28 AM
What is the setting of your Focus Limit Switch on the lens?
04-27-2022 07:36 AM
It does the same thing in either 1.2 or 2.5
04-28-2022 01:16 PM
"people 15 to 50 ft away."
Perhaps not the best for testing AF.
Very first top of the list. Reset the 5D Mk III, great camera BTW, to factory default. There is a possibility you have set something off. Clear all settings and, important, clear all custom settings. Makes sure all the lens switches are in their default positions too. Any AF lens needs vertical lines and contrast to focus the best. After reset try using AF with the problem lens on some things with good contrast and some vertical lines. If it now works, it works and there is nothing wrong with it. If it doesn't it needs to go back to Canon and tell them how you tested it.
04-28-2022 01:46 PM
Reset camera and lens, still runs in and out of focus continuously. Thanks for your suggestion.
04-28-2022 02:45 PM
You need to call Canon again. This time send the lens and the camera.
04-28-2022 03:47 PM
Waiting on Canon to reply to my email. This issue is present with the lens on 3 different cameras. Thanks again for your time and trying to help.
