08-01-2014 08:25 PM
08-02-2014 03:39 PM
The high-end version of a standard zoom with low focal ratio for the 70D is the Canon EF-S 17-55mm f/2.8. That's basically the same focal length range as the typical kit lens (18-55) but it can provide an f/2.8 focal ratio at any focal length rather than varying the focal ratio as the kit lenses tend to do.
08-02-2014 05:44 PM
@TCampbell wrote:The high-end version of a standard zoom with low focal ratio for the 70D is the Canon EF-S 17-55mm f/2.8. That's basically the same focal length range as the typical kit lens (18-55) but it can provide an f/2.8 focal ratio at any focal length rather than varying the focal ratio as the kit lenses tend to do.
My wife (T2i) and I (7D) each have one. We're very happy with them. The lens's only real drawback is that it's a lot bigger and heavier than you might expect. But so is the 24-70 II.
08-03-2014 12:28 PM - edited 08-03-2014 12:30 PM
@TCampbell wrote:
Such is the nature of f/2.8 zooms. In order to lower the focal ratio but maintain the same focal length the physical diameter of the lens has to be increased. Then all the glass elements inside get a larger physical diameter, which also makes them thicker. That may result on stronger dispersion requiring even more corrective elements in the lens. By the time all that happens the lens weights noticeably more.
My solution is to use a more comfortable camera strap. I use a sling type strap (Black Rapid) rather than a traditional neck strap.
Ha ha, but a neck strap doesn't made the 17-50mm f/2.8 EF-S weigh any less.
08-03-2014 11:49 AM
Bob in Boston,
The f-stop is the focal length divided by the diameter of the lens. One example, a 200mm f/4 lens will be 50mm wide. 200mm/50mm = f/4. The light-gathering ability of a lens is determined by its area, and f-stops are determined by diameter.
Now in a zoom lens things are more complicated and corrector lenses are needed. So zooms get heavier as their f ratio goes down (number gets smaller) and very much more costly.
This is a fixed physical condition and it is the reason the lens does not and can not change anything when used on a different body. Be it a FF, medium, or Rebel crop.
08-03-2014 12:14 PM
@ebiggs1 wrote:Bob in Boston,
ebiggs1 writes, "The light-gathering ability of a lens is determined by its area.."
Though a EF lens is unchanged, regardless to the body (duh, there won't be a magic show) it will never be able to fully capitalize on the coverage when mounted on a Crop-sensor body. Imagine a Corvette engine in a Cobalt body which is never able to use much of its capacity. (BTW, I do not mean to suggest that the 70D is anything less than a extremely good camera.)
08-09-2014 08:55 AM
"The lens's only real drawback is that it's a lot bigger and heavier ..."
I could probably think of a few more but whose counting? It is a great lens for 75% of the folks.
08-11-2014 11:50 AM - edited 08-11-2014 11:52 AM
@ebiggs1 wrote:It is a great lens for 75% of the folks.
Whoa there Canon dude. 75% of anyone with a camera. 75% of the people that casually use their DSLR? Which 75%?
Making stuff up is fun, don't you think Bob?
08-11-2014 12:40 PM
The 75% of Canon users who haven't gone FF?
<chuckle!>
BTW, going FF isn't necessarily a reason not to continue to use one's 17-55 f/2.8. If I'm doing an event and the 70-200 is on my 5D3, my second camera will be a 7D with the 17-55.
08-03-2014 11:57 AM - edited 08-03-2014 12:17 PM
Ma49ers1, I wouldn't buy the 70-200 f/2.8 unless you are "working your way" towards a FF body. The lens was optimized for FF shooting and with the crop-sensor 70D, you'll be "wasting" a substantial portion of that lens. Imagine buying a car and only using it within 60% of its capabilities. That's like buying a minivan and never once using the third row seats.
I second, third, or whatever, the 17-55 f/2.8 EF-S as a great option. If you want a faster lens with reach, I'd recommend choosing a prime lens from among the Canon choices of 60mm f/2.8 EF-S macro, 85mm f/1.8 and 100mm f/2 EF lenses. Buying used is also a great way to test lenses without the pressure of a pending sale. Good lenses hold their value and you can generally recoup much of what you spend.
08-10-2014 08:59 AM - edited 08-10-2014 09:00 AM
