11-11-2012 03:25 PM
Hello everyone,
My name is Jake Miille and I am photographer in California. I use a Canon Rebel XSi (Hoping to upgrade to a Canon 7D Mark ii if it comes out in January) as well as a Canon 10-22mm and a 24-105L. I shoot mainly railroads throughout the Western US and sometime 105mm just doesn't cut it. I have been hoping to upgrade my telephoto lens (I do have a kit 55-250 but it's... you know) for awhile. I have seen a few options and I was hoping I could get some of your opinions/advice.
The Canon 100-400 looks like a nice lens and I'm really excited about the coverage it could get me. I am not too worried about the limited aperture because railroad scenes are usually shot on f/7.1 or higher. I have heard the push/pull system can be weird but I have no doubt that I could get use to it. My one concern with this lens is the sharpness and quality. I have heard it is not the sharpest L lens out there and I was wondering how that would affect my photos. I'm a little torn/confused because the lens is Canon L series, but people have discussed it as being a little soft. Does anyone out there have experience with this lens? Is it sharp enough? Will it be worth the money?
If you wouldn't recommend the 100-400, what do you think about the 70-300L? If those two lenses are equal in quality, the 100-400 would give me a better range. Is the 70-300 actually a sharper lens?
Thanks for the help.
11-14-2012 05:43 AM
This was taken with a 100-400 and is sharp enough for me.
11-14-2012 05:54 PM
My 100-400mm is definitely a sharp lens and I have used it handheld on a 5D to capture aircraft in flight where you can count the rivets on the fuselage!
This is uncropped (you can even see the nose of another Rad Arrow bottom left) & unprocessed apart from converting from RAW to jpg with a little sharpening applied.
Hope that helps?
-=Glyn=-
11-14-2012 07:24 PM
The lens can be both very versatile & sharp BUT you'll need to learn proper technique. It's heavy at first, plus it will take a while to learn the push / pull zoom movement while being smooth Higher shutter speeds help too, but depending on what you're shooting & the light you may need to use lower speeds which again comes down to practice.
First sample will be the full frame followed by a tight crop.
11-15-2012 12:55 AM
I have the 100-400 and just LOVE it. The push-pull in my opinion is much faster to zoom than a twist lens. I think it's incredibly sharp. Here's one of my shots with the lens - no complaints here:
11-15-2012 01:56 AM
I just got a refurbished 100-400L from the Canon direct site. I have been very happy with getting Canon refurbished lenses - they look absolutely new, and since each is checked by a technician before sale, I think they are often better calibrated then standard new stock. On my 5D mk II using FoCal to set the MA, my refurbished lenses have been within +/- 1 or 2. As far as being sharp, I agree, good technique is essential. I've had good luck so far handheld and expect future tripod shots to be fantastic. I actually like the push-pull zoom - smooth and easy to zoom from 400 on into 100 as the subject approaches.
This was taken handheld at 400mm and 1/1600 at the Nellis airshow last weekend (about a 50% crop)
This was taken handheld at 400mm and 1/400 at Spring Mountain Motor Ranch just outside of Las Vegas, NV a few weeks back. This is about a 50% crop.
11-15-2012 12:57 PM
Owned it, it isn't all that sharp compared to others in the range.
The reason to go with it is if you need 400mm.
I would prefer the 70-200 f/2.8 L II myself, next would be the 70-300mm L.
If you know what length you need one of the L primes would be even better.
11-15-2012 04:52 PM
@SusanK wrote:I have the 100-400 and just LOVE it. The push-pull in my opinion is much faster to zoom than a twist lens. I think it's incredibly sharp. Here's one of my shots with the lens - no complaints here:
Incredible exposure, well done!
11-15-2012 04:54 PM
Wow...just wow! That's a stunning picture. Do you have the story on that one to share please?
-=Glyn=-
11-15-2012 05:07 PM
^^^^Sure seems locked on target^^^^
11-15-2012 05:34 PM
