10-16-2024
10:01 AM
10:03 AM
Hello Canon Community, I would like to ask if a Yongnuo YN 50mm f1.8 autofocus prime lens V1 going to be good for like school events photography i most of the time can get decently close to the subject will this be good lens for my Brand New Canon EOS 500D?
10-16-2024 11:57 AM
jorekco1,
Just make sure you get the Yongnuo for Canon EF mount. B&H sells these for $82.00 right now. It should be okay, if, as you say, you can get decently close.
Steve Thomas
10-16-2024 12:44 PM
Why not go for the Canon? It is not that much more expensive.
10-16-2024 01:08 PM
Also I found out Yongnuo lenses don't work properly on older cameras. Also a 50mm is a mild telephoto on APS-C so it would be difficult to use when vlogging.
10-16-2024 01:53 PM
Exactly what I was thinking. It's a much better option.
10-17-2024 10:47 AM - edited 10-19-2024 10:25 AM
I wouldn't buy it.
"Why not go for the Canon? It is not that much more expensive." And about, oh, a thousand times better. Not trying to be rude but the Yongnuo YN 50mm f/1.8 is a bad idea. Considering.
10-19-2024 12:08 AM
jorekco1,
I guess the obvious question to ask is, have you ever shot with a 50mm before to guage it's field of view? Will a 50mm satisfy your needs?
What type of events did you have in mind?
Steve Thomas
10-19-2024 08:25 AM
“ will this be a good lens for my Brand New Canon EOS 500D? “
The 500D? Brand new? I guess.
10-19-2024 01:43 PM - edited 10-19-2024 01:50 PM
jorekco1,
You said, "most of the time can get decently close to the subject". If I may, I'll answer/make a recommendation based on my experience and my assumptions.
Hope the above helps.
LZ
