03-28-2015 06:22 PM
03-28-2015 06:35 PM - edited 03-28-2015 06:37 PM
If I had that lens, I think I'd use it primarily as an indoor event lens. It's awfully big and heavy to use as a walking-around lens, which I believe is what you're proposing. IMO, a much better walker is the 24-105mm f/4L IS: smaller, lighter, better range, and much cheaper. And it's stabilized, while the 24-70 isn't.
03-29-2015 12:31 AM - edited 03-29-2015 12:47 AM
03-30-2015 11:04 AM
And now for the straight skinny....
The EF 24-70mm f2.8 L II is the best lens of its type made. In the world, period. End of story. Nobody makes a better lens.
The EF 24-105mm f4 L IS is the "best buy" for a lens of its type. Also, period.
So if you want the best and closest to a "do all" there are your choices. Of course neither is a complete "do all". You need one more lens, the EF 70-200mm f2.8 L IS II. Best buy version EF 70-200mm f4 L non-IS model.
03-30-2015 11:33 AM
On a "full frame" camera such as the 6D, the 24-70 offers a nice range from wide-angle to very moderate amount of telephoto. Optically it's an excellent top-notch lens. You may find that, at times, you wish you had a bit more on the telephoto end. But the advantage of the 24-70 f/2.8 is that it gathers more light and will perform better in indoor and other low-light situations.
At some point, you will likely want a lens that can offer a longer focal length. But if you just bought a lens with a longer focal length in the zoom range, then at some point you'd also be wishing you had a lens that could offer a lower focal ratio (e.g. the f/2.8 lens.)
So there is no "best".
The 24-70 is a better lens than the 24-105 if you compare how they perform in the 24-70 range (ignoring that the 24-105 has a range from 70-105 that is missing from the other lens.)
I went with the 24-70 f/2.8 (the original... the II didn't exist back when I bought my lens) because I also had the 70-200mm f/2.8 -- so for me, I had the longer focal lengths covered with a different lens and wasn't missing out on anything.
