11-24-2023 06:11 AM
Hello,
I just would like to report the total incompatibility between Irix 15mm and the new R6 mark 2. I hope for a firmware update on Canon side but if ever somebody has a temporary fix, that would be great.
In the end we would just need to be able to set up the aperture at 8 or 11 and that would be it... Maybe with a small trick on the connectors ??
03-11-2024 07:22 AM
To the Moderators. This thread should be marked solved. The OP was advised to contact the lens manufacturer for a firmware update. OP did and problem was solved.
12-03-2023 09:47 AM
@Iphosia wrote:Well, if that doesn’t happen, my buying a next canon camera neither. No use to stay faithful to the brand if they behave like this.
You have yet to describe the issue or problem that you are having with the lens!
I can understand your disappointment. Canon did not design and build the Irix lenses. Irix made the claim to be compatible with the EF mount, not Canon.
You need to contact Irix about the issue, but i suspect I know what they will say. “The lens is designed for the EF mount, not the RF mount.”
Other brands do not have compatibility issues when adapted to the RF mount. I am uncertain if Irix can update the lens firmware even if they wanted to. Canon has prohibited third party lens manufacturers from producing and releasing products that communicate with RF mount camera bodies.
12-12-2023 12:55 AM
The camera goes black as it doesn't detect the aperture. Only way to fix it is pop the battery out.
Well... I do understand that Canon wants more of our money and recreate proprietary mount... but in 2023, this is really pissing me off. That will probably sign the end of my Canon era. Next, I will just pick the body I like since in any case, I cannot go on using my old lenses.
12-03-2023 10:38 AM
Canon entertains licensing of the RF-mount to third parties. However, it doesn't just issue a blanket license for off brand manufacturers for a RF compatible mount. Canon reviews third-party lens licensing request one at a time and individually. I suspect we will see lenses from Sigma and Tamron soon.
12-12-2023 12:51 AM
Tamron EF mount lenses are working fine. By the way. At least my 100mm macro is.
12-12-2023 03:50 AM
@Iphosia wrote:Tamron EF mount lenses are working fine. By the way. At least my 100mm macro is.
This statement only supports what you are being told. Your issue is a lens problem. The Tamron EF lens works just fine. But the Irix EF lens does not. My Sigma EF lenses also work just fine with the Canon EF/RF mount adapter.
12-03-2023 11:00 AM
@Iphosia wrote:Hello,
Irix has already reported that their lenses are not compatible with the R3, R7 and R10, so it is likely they just haven't updated their list for the latest R body.
12-12-2023 12:50 AM
Yes, but I don't see how they could update anything...
Besides... in nowadays long speaches about sustainability, it is really a common but **bleep**ty move from Canon to reinforce a patent to artificially render some lenses obsolete... All the more ridiculous as this just makes customers angry and will not make them buy new lenses. Even worse, I was planning to buy an RF but I won't.
Of course, you always have the unreal fanboys who seems happy to get screwed by brands 🙂
Well... let's wait and see.
12-12-2023 03:59 AM - edited 12-12-2023 04:03 AM
@Iphosia wrote:Yes, but I don't see how they could update anything...
First and foremost. This forum is not Canon Support and Service.
This Canon rant about your incompatible third party lens being Canon’s fault is probably one reason why Canon enforced their intellectual property against third party manufacturers.
A lot of users were making similar complaints about this and several other inexpensive brands of camera lenses and mount adapters. They were demanding a solution from Canon to allow their third party, EF mount lens gear to work on the new RF mount. Most of which was being sold before the RF mount was ever announced and released.
You have been asked or advised to contact Irix more than once. What has been the manufacturer’s response, if any?
12-12-2023 10:55 AM
" Next, I will just pick the body I like since in any case, ..."
And you think all will be happy days and blue skies. No issues what so ever. How naive you must be.
01-27-2024 06:29 AM
Contact Irix via info@irixlens.com
They have FW update available to make the lenses compatible with the R3, R6II etc.
I live in Germany and had to send my lens (11mm 4.0) to the IRIX Service Center in Poland. There the lens was updated to the new GW within two days and sent back free of charge. This was in Novemer 2023. They may offer a similar service in your region.
