04-25-2013 08:48 AM
04-29-2013 05:56 PM
Hi Kingcreek,
As long as you purchase your lens new from an authorized dealer (keep your receipt) in the United States or Canada, your lens has a one year limited warranty.
04-25-2013 11:06 AM - edited 04-25-2013 11:06 AM
The II means that it's the second version of the lens, not related to the IS specifically. A quick look online suggests that the Mark II version is another case of Canon peddling the same old sh!t with a pretty new bow (see also: the 700D). I don't see a single performance increase mentioned.
That said, I had the Mark I version and used it for many years, and it was fine. It's not some amazing lens, but as you said, you get what you pay for. I can't speak to the 75-300 from personal use. Looks like the IQ is about the same. The 55-250 is smaller and lighter and won't leave a gap for you between 55 and 75. The 250 also has a closer minimum focus distance. Obviously the 300 gives a bit more reach.
04-25-2013 01:06 PM
04-29-2013 05:56 PM
Hi Kingcreek,
