11-16-2020 11:26 AM
Trying to decide whether to send out for service or list on Ebay.
Faulty Canon EF 70-200mm f/2.8L USM, purchased in 2016 from B&H in NYC.
Throws a code saying lens is not connected to camera. Has worked fine til now.
Local long-existing camera shop did assessment. Recommends sending for further assessment and repair, assuming it's an electronic issue.
Anyone have this same issue.
Thanks.
11-16-2020 11:43 AM
Welcome to the forum.
Assuming it is an accurate l;isting on eBay I don't suspect you will get a lot of money for a non-functioning lens.
Send it to Canon for an estimate.
11-16-2020 12:11 PM - edited 11-16-2020 12:17 PM
A used Canon 70-200mm f/2.8L is worth about $800. I bet Canon can repair it for less than that.
BUT.... If you accurately describe it's problem, and sell it on eBay, you might get a good price for it. Many of these "lenses for repair" fetch $400 or more on eBay. You can check the "Sold" listings on eBay. eBay EF 70-200mm f/2.8 SOLD LISTINGS
You could then use the money to replace your lens for about $800, or use the money towards upgrading to a EF 70-200mm f/2.8L IS II or IS III.
11-16-2020 04:28 PM
Thank you! That is the plan as of now.
11-16-2020 04:28 PM
11-16-2020 05:03 PM
The lens needs to go to Canon for an evaluation. That is by far the cheapest way to go. The idea of replacing it with Mk II or Mk III is fine but I doubt you will see a huge difference in IQ. The Mk III is over two grand, remember. It is that much better and worth it to you? If you say, yes it is, then go for it. Otherwise, call Canon and set up a service ticket.
