10-07-2024 02:11 AM - last edited on 10-08-2024 08:55 AM by Danny
has Canon 28-70 f2.8 zoom NOT marked "ultrasonic" is this an earlier model?
All seen online are so marked
10-07-2024 07:54 AM
Can you post a photo of your lens?
10-07-2024 09:57 AM
excuse quality of image. UB0600 0n rear and 112040 on bottom edge
10-07-2024 10:07 AM - edited 10-07-2024 10:09 AM
I don't think that’s the f/2.8L version. No red ring Looks like the f/3.5 lens.
10-07-2024 10:32 AM - edited 10-07-2024 10:44 AM
The UC600 means it was made in June 1987 at our Utsunomiya, Japan factory.
Based on that, I'm confident that the lens is the EF28-70mm f/3.5-4.5.
10-07-2024 10:39 AM
Yes Stephen I have an old EF 70-210mm F/4 lens. It was also made in Japan too. I believe all of these early EOS system lenses were made there.
10-07-2024 10:42 AM
We still make our lenses in Japan. I should have been more specific, so I'm revising the post!
10-07-2024 10:45 AM
I was specifically talking about the AF motor type. All Arc Form Drive lenses came from that factory and nowhere else. Even as recently as 2022.
10-07-2024 10:28 AM
That's an older Arc Form Drive AF motor lens. The reason you can tell is because the date code starts with a "U". Only Arc Form Drive AF motor lenses were made there and nowhere else.
10-07-2024 03:58 PM
Thanks to everybody for those useful responses!
