01-30-2023 11:07 AM
Hello all, I bought a used EF 500mm F4 L IS USM apparently in near mint condition the only issue I have with it is that the focus preset does not work with my R5 or my 7d mark ii. Doe any one have any knowledge if this feature is or is not supported on the R5 or 7d2 with older EF Lenses?
I would appreciate any help, Thx
01-30-2023 12:19 PM - edited 01-30-2023 12:23 PM
It is not supported in Live view mode (7D II) or with any mirrorless camera from Canon. 7D II in viewfinder mode should work.
Focus Preset with my EF 300/2.8L IS USM doesn't work with my R6/M5. Only works with my DSLR cameras in viewfinder mode.
It is similar to EF 35-80 Power Zoom. Zoom is not working in live view or with any mirrorless camera from Canon.
01-30-2023 12:25 PM
Why would it not work with MILC bodies? The entire process of defining a preset and recalling it appears to be completely independent of the camera. You are even instructed not to press the shutter.
01-30-2023 01:26 PM
Canon wrote this for version II https://support.usa.canon.com/kb/index?page=content&id=ART174644
01-30-2023 01:43 PM
My bad I guess I should have specified my EF 500mm L IS is not a version II. It's the previous version I guess that would be version I.
01-30-2023 02:11 PM - edited 01-30-2023 02:13 PM
I have version I of 300/2.8L IS USM. Do you have an older camera to try with?
Focus preset ON, focus with the AF button, press SET to save the distance and use the ring at the front of the lens.
01-30-2023 03:49 PM
I have a canon T2 that I let my son use, I was thinking of trying it with that Camera.
01-30-2023 12:49 PM
Thx Peter, I can't get it to work with my 7d M2 even on viewfinder mode.
01-30-2023 01:27 PM
No idea. Works with my 6D and 7D.
01-30-2023 05:11 PM - edited 01-30-2023 05:14 PM
@Lumo1960 wrote:Thx Peter, I can't get it to work with my 7d M2 even on viewfinder mode.
How are you trying to recall the focus preset?
This lens was released in 1999. As per the User Manual, the shutter does not need to be used to set it or recall the preset. It is all done on the lens. I believe this is the same manual for Peter’s lens.
[EDIT] Make sure the metering system in the viewfinder is active, too.
