03-08-2025
11:55 AM
11:59 AM
SamanthaW
Hello, so i bought my r6 mark ii and i bought a sigma lens the 24-70 art.And the focus is just missing,it is giving me pictures like shooting on a slow shutter while shooting on a >1/1000 shutter speed and wanted to ask can i calibrate it from home or i need to go to a service because am very far away from every service for the sigma lens?
03-08-2025 12:07 PM
Mirrorless cameras cannot front or back focus so there is no AFMA (Autofocus Micro Adjustment)/ AF Fine Tune. Also what is the Full Name of your Sigma lens. What mode is the camera's top mode dial set to also what is your ambient lighting like. What is the shutter speed the camera is setting 1/1000th is a fast shutter speed. Also what mount adapter are you using the Canon brand mount adapter or a 3rd Party mount adapter. 3rd Party Mount adapters are nothing but trouble and cause all sorts of problems. Such as the camera locking up, no communication with the lens etc.
03-08-2025 02:46 PM
Milan, if you like the lens pick up a Sigma USB Dock for Canon EF-Mount lenses and download the dock required SIGMA Optimization Pro software. The dock will allow you to update the lens firmware but more importantly it also allow you to adjust focus position, AF parameters, OS settings, etc. (select lenses). Customize rotation sensitivity of focus ring in MF mode (select lenses).
The instructions for how to use the dock and software are terrible but there are some outstanding videos on youtube to assist you.This video shoot to the 5:30 mark for lens calibration.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
03-08-2025 12:07 PM
03-08-2025 12:18 PM - edited 03-08-2025 12:24 PM
You can use third-party software for R6 to adjust the AF (limited to 7 lenses), but it may take a year before R6 II is supported.
03-08-2025 12:59 PM
I am using the canon adapter,I am shooting manual.It is the Sigma Art 24-70mm DG OS HSM EF mount the photos are not sharp when i zoom in to 70mm it is giving me shaky vibes like it is shooting on a slower shutter like 1/40 or 1/30 I can post a picture so you can see it or make you a link from the photos that i took.I think the problem is within the lens some update or some calibration and if you know how to it manually from home i will be pleased.Thank you for your response.
03-08-2025 01:06 PM
Does that lens have IS are you setting your shutter to a slow one. If so the picture would have camera shake then. If this lens has IS turn it off and see if the problem persists. A lot of older Sigma often times plays "IS tug of war" with the AF system and also with cameras with IBIS. Does the image shake in the viewfinder or rear LCD screen. Some Sigma lenses support's Sigma's dock for updating the firmware. But a lot of older lenses do not support the dock in this case the lens would have to be sent to Sigma. Have you tried a Canon lens to see if it continues to happen. Also post a picture in the forum so forum users can better assist you.
03-08-2025 01:13 PM
yes I have tried with and without the OS on the lens and the shutter speed was faster than 1/1000 of a second and before the sigma i was using the RF 50mm 1.8 it was working perfectly I can buy a dock but i dont know if it is going to work so i dont want to spend more money on a gear that doesn't work properly.
03-08-2025 01:22 PM
Can you post a picture in the forum to show how the pictures come out.
03-08-2025 02:46 PM
Personal Gallery
03-08-2025 05:44 PM
Thank you so much for your time so i don't need to attach anything to my camera its just the dock and the lens thank you !!
03-08-2025 05:50 PM
Yes, you can pick them used for $20 or new for about $45. Watch the video, there is a process to follow to obtain improved focus.
Personal Gallery
