03-14-2021 07:34 PM
Equipment:
EOS 5D
EOS 5D Mark III
EF24-105mm f/4L IS USM
EF70-200mm f/4L USM
I bought a EOS 5D back in the days with a EF24-105mm f/4L IS USM lens.
The camera died recently so I bought a used EOS 5D Mark III.
After shooting a few shots, the camera wont work with the EF24-105.
The camera works fine with my old EF70-200mm f/4L USM but not my EF24-105mm f/4L IS USM.
Could it be that EOS 5D Mark III is not compatible with EF24-105mm f/4L IS USM?
I've heard from someone else, that they had a problem too. Something about the lens not working the minute they used focus, zoom or something like that.
Anyone know of this problem?
Thanks,
G. Falkenberg
03-14-2021 09:53 PM
Your 5D Mark III will be compatible with any EF lens including the EF 24-105 f/4.
When your original 5D failed, do you recall what lens you had on at the time? A long shot, but I'm wondering if the 24-105 was at fault and somehow damaged the camera?
For the 24-105, do all modes fail? e.g. manual vs auto-focus. IS on/off. Different apertures (e.g. wide open at f/4, then stopped down).
03-15-2021 02:27 AM
03-15-2021 03:31 AM
@Falkenberg wrote:
I had the same thought, but skipped it as lenses rarely die. Mostly it’s the cameras that dies.
But you are right. I was using that lens when my camera died.
What happened was, that the shutter opened but wouldn’t close again before I turned off the cam. And the first time I tried to shoot, same thing happened.
The cam is put away. A new one bought. But lens seems to be damaged. Or I experience something similar to what someone else on the Internet also experienced. So I’m not sure. And I don’t dare to test it again and kill the new cam.
If you have recently purchased a 5D3, it sounds like it was most likely used. Have you reset the camera back to factory defaults, yet? This should be done with any used camera purchase to put the camera back into a known state.
Many of the menu options open up to complex sub-menus, which have their own reset option. A good example of this is the Custom Controls menu, which is used to program control buttons for BBF and other features.
I suggest doing the basic, factory default reset with your camera, just to see if it helps with your lens problem.
03-15-2021 10:44 AM
" Have you reset the camera back to factory defaults, yet?"
Not only should you do this on the new purchased camera but on your old one also. It is very unlikely that any EF lens can damage a 5D series camera. I would suggest a full reset as you set something incorrectly or the camera did just fail of its own accord. Perhaps you new one did also. You never know about older gear about how long it has.
You can try the unlikely chance that the contacts on the lens are dirty. If you left the lens on for very long periods of time with out changing it it is worth a try. Get some denatured alcohol and a Q-tip and very lightly rub the contacts. Very lightly! They are gold plated and it is very thin. It can easily be damaged by cleaning if done too vigorously.
Of course new CF cards and batteries are a good idea too!
03-15-2021 06:49 AM
