10-02-2015 01:55 PM - edited 10-02-2015 01:56 PM
Good evening,
Please excuse me if this is a dumb question.
If I use an EF-S lens on a camera with an APS-C sensor, does the sensor capture all that I see in the viewfinder i,e, with a ratio of 1:1?
Put another way; do EF-S lenses overcome the Image Conversion Factor or Crop Factor that hapens with EF lenses on cameras with an APS-C sensor?
The Crop Factor means that what you see through the viewfinder is more than actually gets captured by the sensor by a ratio of 1:1.6.
I understand that the rear of the EF-S lens is closer to the mirror and, therefore the sensor, than the rear of the EF lens, which leads me to think that the image seen through the viewfinder with an EF-S lens is closer to that which will appear on the sensor than that of an EF lens.
Many thanks for any response that confirms or refutes my supposition, preferably with an explanation in simple terms.
Joe.
01-23-2018 04:02 AM
01-23-2018 05:31 AM
@photosbylorenz wrote:
Thanks John. Not the answer that I was hoping for, but at least I understand it now and I will shop for a 10mm lens for my interior shots.
There are two wide angle Canon zoom lenses made for EF-S mounts, a 10-18mm STM, and a 10-22mm USM.
01-23-2018 05:10 PM
01-23-2018 06:05 PM
Crop factor is a big joke. It is a meaningless term invented to slap on certain sensors because they had to come up with something.It is nothing short of confusing to most people. Even long time photographers think the crop sensor camera actually crops their image. People on all the photography forums will say so. It crops nothing! All camera no matter what size sensor they have are FF in the sense that you get what you see in the viewfinder, nominally.
If you notice they don't call P&S cameras "really cropped sensor". And they don't call medium format cameras "expando sensors".
Again if you have a 50mm lens and could put it on a P&S it would still be a 50mm lens. Even putting it on the medium format or large format body, it is still a 50mm lens.
A better way to think about it is "angle-of-view". There are charts that quickly tell you exactly what it is. On your 'crop sensor' body you need a 18mm to 16mm for a WA angle of view. A 14mm to 10mm is considered an ultra wide angle.
01-23-2018 11:41 PM
I agree with Ernie that angle of view is a more comprehensible comparison vehicle than crop factor. But I think it's even easier to simply learn how a given lens behaves on each type of camera. I've found that the only times I've had to actually consider a len's "full-frame equivalence" is when I'm planning a shoot with both a FF and an APS-C camera, to make sure I don't have a coverage gap.
01-24-2018 10:46 AM
Back in the day, when 35mm film was dominant in the market, for better or worse, the focal lenghts of the lenses for the 35mm system became the standard nomenclature for a particular angle of view.
Along came APS (Which I liked by the way, it was a good bridge to digital, with a first stab at film based "EXIF", but I digress). Since all the major manufacturers had interchangeable lens APS systems, there had to be a way to explain that the angle-of-view of a 50mm lens for APS was different than for 35mm and crop factor was born.
Since the first digital bodies had APS sized sensors, it was natural to keep 35mm focal lengths as the "standard" and use a crop factor to get a handle on the angle of view.
I think it is a handy way to understand the angle of view for a particular focal length. To answer the question above, it only matters for interchangeable lenses.
01-26-2018 09:33 PM
