EF-S 18-135mm f/3.5-5.6 IS STM - Best Way To Set Focus on Infinity?
wchettel
Enthusiast
I am using a Canon EOS Rebel SL2 with a Canon EF-S18-135mm f3.5-5.6 IS STM lens. Is there an easy way to set the focus on infinity when I'm using MF mode on the lens? I just want to set it and forget it.
Walter
in Davie, FL
" I just want to set it and forget it."  " I occasionally like to take pics of the moon and stars ..."
That is one way to shoot nighttime stars. Set the lens to MF.  Use the widest aperture.  Focus in the day time on something you can see that is very far away and put a small piece of tape on the focus ring.  In the dark use your Liveview option to focus.
51 REPLIES 51
BTW, there has been several 18-135mm lenses the current, 2016, model is the best.
How do I determine which model I have? It is the EF-S 18-135mm f3.5-5.6 IS STM lens.
Walter
in Davie, FL
If you bought it after 2016 it is probably the most up to date version.  If you purchased it much after 2016 it is certainly the newest version. Is your lens the Canon EF-S 18-135mm f/3.5-5.6 IS USM Lens? Does it look like this?
Don't get me wrong this is a pretty good all around lens.  It is not a good astro lens. No matter what others have said. They simply don't know what they are talking about. No astro photographer would use it. For general use it is actually one of the better choices and the latest version is the best one yet. If I were in the market for a Rebel I would choose this lens over the standard kit lens every time.
The STM and USM versions of the lenses have identical optics, 16 elements in 12 groups.  Even the predecessor to these [two] lenses has the same optics, 16 elements in 12 groups, including one UD element and one aspherical element.
The only difference between the lenses are the AF motors.  The accuracy of the  autofocusing improved with each AF motor system, but the optics remained the same.  When you manual focus on the stars the differences are irrelevant.
"Fooling computers since 1972."
Yes, it is a Canon lens, but it's the STM version, not the nano USM version. I bought it a few months ago from Amazon. This is my lens.
Also, I am NOT an astrophotographer! I'm just a casual picture taker that likes to take a pic of the Moon or stars every once in a while. Here is a pic of the Moon that I took with a Panasonic Lumix FZ80 that I had before I got my Canon Rebel SL2.
Thanks for your feedback!
Walter
in Davie, FL
" I'm just a casual picture taker that likes to take a pic of the Moon or stars every once in a while."
In that case the lens is perfect for you.  Enjoy and shoot away! Smiley Happy
The "STM" in its name indicates that it's one of the newer "stepping motor" lenses. It's an optically good lens, but its main claim to fame is that it focuses very quietly, which is important if you're shooting sound video, Even its "manual" focus is done electrically, which puts some people off. But it is considered a good lens overall.
Bob
I don't own this lens or any 18-135mm but I believe the USM is the newest.  Right, wrong?  To me it would be the prefered model.
ex347p
Sorry, you might have figured it out already and I know it is a ridicules way. But... What I do - turn manual focus on of course, then turn the focus ring counter-clockwise (depending on your settings) util a dimmed triangle appears right of the infinity sign. Then slowly turn the focus ring backwards until that triangle disappears - then you are at the infinity focus... But note the you have to do it every time you turn the camera off/on!
ebiggs1
You do know this is a 5 year old thread. Some of the responders have even passed away.
