EF-S 17-85 lens autofocus keeps seeking
orthodr
I have an EF-S 17-85 zoom that is probably 12 years old and it now keeps searching when trying to focus and gives an error message 01 and says to clean the contacts which I have done without success
6 REPLIES 6
Moderator
Moderator
Hi, orthodr!
So that the Community can help you better, we need to know exactly which Canon camera model you're using this lens on. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
deebatman316
The flex cable in the lens sounds like it could be faulty. But first reset the camera back to factory and the custom functions back to factory default. Then retest to see if its a possible setting problem. Also test in live view to see if the camera will focus. Also what camera are you using.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
orthodr
Canon 50D
Do you have other EF or EF-S lenses to test on the camera to see if they will AF.
-Demetrius
works fine with my other lenses
Sounds like the lens is need of repair. I don't believe Canon supports this lens anymore. But used ones can be found.
-Demetrius
