06-07-2014 08:05 PM - edited 06-07-2014 09:55 PM
06-15-2014 06:25 PM
And the lens does this on both camera bodies? Yes? The lens is bad. It needs to be evaluated by Canon service to see if repair is feasible. Cost may be prohibitive.
06-15-2014 06:42 PM
06-15-2014 07:11 PM
Well all is not lost yet. Have it evaluated.
But remember anything made by the hand of Man can and will eventualy fail. ![]()
This is a good lens and is probably better than anything else in it's focal length. There are offerings from the 3rd party world but they will be no better QA wise or construction wise. I have the very same lens and I also like it very much.
06-16-2014 11:53 PM - edited 06-16-2014 11:57 PM
Your lens needs to go in for evaluation and repair. It looks like a badly decentered lens element to me. That requires disassembly and repair. No amount of fooling around with it or cleaning the contacts will make it work right.
It appears not to be a fault of the camera itself, especially if your other lenses focus correctly. In fact it's not really the auto focus system at fault, when part of an image is out of focus like that, while the other part (in the same plane of focus) is sharp. It's gotta be an optical fault within the lens.
Probably the reason it appeared to work differently ("better", but still not right) on another camera is because it was set up to use a smaller aperture, giving more depth of field that covered up some of the fault of the lens.
If, as you say, 90% of the images are bad... that implies the other 10% are okay. Check those and see if a smaller (higher f-number like 11, 16 or 22) is being used, rendering more depth of field. Otherwise, it might be a loose element or focusing group, that's finding focus one out of ten times, but failing the rest.
No matter, really. The lens needs to go in for evaluation and, if economically sensible, repair.
Alan Myers
San Jose, Calif., USA
FLICKR & PRINTROOM
06-17-2014 06:43 AM
06-17-2014 06:53 AM
Although the 10-22mm is a good lens I would prefer the EF 17-40mm f4 L. This is just my personal prefference but I no longer buy any EF-S glass. There has to be a very goood reason to break that rule for me. There is no "L" made in EF-S for instance.
06-17-2014 09:01 AM
06-17-2014 10:07 AM
You already know my answer.
"... I no longer buy any EF-S glass."
06-18-2014 08:12 AM
06-18-2014 08:26 AM
Thank you all. I am going to send in the EF-S 10-22 to Canon and hope the cost is not too high to repair an already costly lens. I am buying a Tamron AF 17-50 mm F/2.8 SP XR Di II VC to have for this weekend sons grad party since my go to Canon lens for this type of family shots is out of serveice.
Feeling a little burned on the Canon lens, I paided the higher lens cost for the Canon expecting longer service and quality then I received. But since I am a novice I am going to give Tamron a try for my future business this go around.
