07-31-2026
12:28 AM
09:22 AM
Hello,
Getting back into photography from my 35mm film days. I bought a 6D and while my EF 50mm f/1.8 STM was found in the EOS utility and uploaded its aberration data, my EF 75-300mm f/4-5.6 IS USM is not listed. I looked on the "great internet machine" for information and all I found was vintage lenses like this were dropped from the utility.
Is there a way to add the data manually? If so, how do I get the values to add the 6D body?
Any and all help/ideas/suggestions are appreciated. Thanks in Advance.
07-31-2026 12:25 PM
@DarkJedi wrote:
Hello,
Is there a way to add the data manually? If so, how do I get the values to add the 6D body?Any and all help/ideas/suggestions are appreciated. Thanks in Advance.
That is a very old lens (circa 1995) and it may not have lens data since it is pre-digital era.
https://global.canon/en/c-museum/product/ef330.html
07-31-2026 04:39 AM
Double check the lens model number. It could be 70-300mm, not 75-300mm.
07-31-2026 07:39 AM - edited 07-31-2026 07:42 AM
In Canon DPP software, I see it as an option to download. I am not certain I understand the question.
Maybe this is your lens: https://global.canon/en/c-museum/product/ef310.html
07-31-2026 11:23 AM
"Is there a way to add the data manually? If so, how do I get the values to add the 6D body?"
You didn't mention what editor you are using if it is Photoshop/Lightroom you can use the Adobe Lens Profile Creator to make your own for any lens. Then create a preset that applies upon import to LR. Done slam bam thank you mam. Get on the "great internet machine" where there will be hundreds of how-to videos if you don't know how to. 😁
07-31-2026 12:25 PM
@DarkJedi wrote:
Hello,
