EF 70-200mm f2.4 II IS slows down burst mode on EOS R6, okay on EOS R7
Hodiernal
Get ready to dive into a world where big **bleep** aren't just celebrated; they're worshipped. Looking for busty girls getting down and dirty? You're in the right spot. We've stocked up on free videos featuring the hottest babes with huge boobs that just can't keep their hands off each other—or anyone else.
https://hugetits.me/videos/51632/pov-pale-innocent-chokes-on-bbc/
https://bigtitsporn.xxx/videos/23298/
https://www.bigtitstube.xxx/videos/44366/fat-maid-for-cute-sex/
You want hardcore? You got it. These well-endowed ladies are not playing around. They love it rough and wild, and they're ready to show you how much. Watch them bounce and jiggle while taking it deep from all angles. No gentle stuff here; it's all about hard **bleep**ing that makes those massive melons shake like crazy!
5 REPLIES 5
p4pictures
This does seem strange as I have that lens and an EOS R6. With the EF 70-200mm f/2.8L IS II USM fitted there is no difference in the high speed drive operation compared to using an RF lens. Make sure you have LP-E6NH batteries fitted and the icon on the LCD is showing H+ in green.
EOS R5 and EOS R6 both have some limitations at the high speed + drive mode with older EF lenses and there is a list in the manual on page 859 that shows the lenses compatible with 12fps. There it says the lens is compatible.
However I note you typed f2.4 is your lens the f/4 version, not the f/2.8 version? If so then the EF 70-200mm f/4L IS USM does not support high speed 12fps shooting, yet the EF 70-200mm f/4L IS II USM does.
Brian
Waddizzle
You have not posted enough info to understand the problem.  Tell us how to reproduce your issue. Post a sample photo with EXIF data that demonstrates the issues you are experiencing.
I'm not sure EXIF info will provide any insight into burst speed.
You’re correct.  That is why I asked the OP to tell us how to reproduce the issue.  We know nothing about AF settings, AF points, etc.  I figured we could start small and work up from there.
deebatman316
Can you provide the Full complete name of the lens in question. Canon hasn't released an EF 70-200mm f2.4 II IS lens. They've made F/2.8 & F/4 versions of lenses including IS and non-IS versions. The version 1 IS of the F/4 and the original non-IS versions DO NOT support 12 fps. The F/2.8 models the original non-IS and version 1 IS DO NOT support 12 fps. The newer variants of the F2.8 & F/4 lenses do.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
