EF 70-200 2.8 IS USM: does not focus
NancyEv
Recently, I am unable to focus my lens using the focus ring (stuck on infinity-when I turn the ring, nothing happens (R7 camera).  When I try to use center point focus, the camera cannot focus on things closer than infinity.  Sometimes Eye-detect works, but most of the time it doesn’t.  Also, when I shoot in eye-detect mode, the first picture is sometimes good, but subsequent images lose focus.  Thoughts?
17 REPLIES 17
When I turn the focus ring when the lens is off the camera, nothing happens in the focus window.
Even if you turn it both ways? Do you feel any resistance when turning it. The focus ring should turn indefinitely. You'll feel resistance at the end of the focus through. But it will keep turning.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L USM, EF 24-70mm F/2.8L USM, EF 70-200mm F/2.8L IS III USM, EF 50mm F/1.8 STM, EF 85mm F/1.8 USM, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D
Slight resistance when turning either way and no change in resistance even when turning the ring 3-5x around.
There should be a part where it turns smoothly without resistance. Until you get to the end of the focus throw. The focus ring will turn 360 degrees. But there is a clutch underneath the focus ring. It sounds as if your lens is broken.
-Demetrius
Tronhard
Hmmm... thanks for that info.
Well, my first thought is to look at the configuration of the R7.  Can you please check to see if you have the latest firmware updates for your camera?  If not, I would suggest doing the update and retesting.
The other thing I would suggest is, after saving your current configuration to one of the C modes, is to do a camera reset and check to see how it is then performing.
cheers, TREVOR
"The Amount of Misery expands to fill the space available"
I have updated the firmware to 1.4.0.  I will do a camera reset today.  I think I'll take it all the way back to factory settings just to be complete.  I will post with the results.
ebiggs1
I would do the reset and clear all custom settings too. I would not save your current settings because if that is the issue why would you want them back. I also doubt a FW update will accomplish any improvement unless it specifically mentions your specific lens.
Sorry to say but this may be user error.
Will do today...I agree that some of the behavior may be user error (or lens error compounded by user error), but I've been using this lens forever and the lack of being able to focus manually seems outside of the realm of an error on my part.
