EF 50mm f/1.4
bluesjb1
For whatever reason my EF 50mm f/1.4 will no longer open wider than 2.8 or close more than f/8.
I currently have the lens mounted on my 5d mk iv. The problem doesn’t replicate its self on my 7d mkii, or my 70d.
Can anyone out there help me identify & fix this issue?
No, the camera isn’t new to me but, I did make some changes with limiting ISO and shutter speed.🤔 Didn’t think I set them as them as custom settings but I will check that out.
Thank you for that!
2 REPLIES 2
jrhoffman75
Is the camera new to you? Does it happen with other lenses?
Depending on those answers check and see if there are custom settings enabled that limit lens opening; some models have that capability.
Thank you for that!
