01-12-2014 10:56 PM - edited 01-12-2014 10:59 PM
I'm looking for some advice about this lens I purchased a couple of months ago.
I seem to get excessive flaring and ghosting when shooting in bright light. I do expect to get some of these artifacts especially when shooting directly in to the sun but I'm concerned there may be an issue with the copy I have. I've seen that some of the older models suffered from this but the date code on this one is from 2013.
This was taken with no filters and hood on at f/16 on my 60D - I would expect the starring to be more defined at this aperture, and I wouldn't expect to see the flare in the trees on the left:
Here's another, this time with the sun out of shot:
Would appreciate your thoughts.
Thanks
Ben
01-13-2014 07:46 AM
I can't say for sure if that flare is excessive as almost any lens will flare under the right conditions. Here is some info on the original Canon recall: http://www.luminous-landscape.com/essays/canon-flare.shtml
If it is still on Warranty I would send it in just to be sure.
Here is what Canon said about it way back then:
From Canon USA
We have recently discovered a problem with early production samples of the
EF24-105mm f/4L IS USM lens in which flare occurs at an unacceptable level under
certain conditions. The flare is most obvious in the wide zoom and wide aperture
settings.
01-15-2014 06:24 AM
benspires,
For your reference, the complete service advisory is posted on our website. Please refer to the following link:
If you have one of the affected lenses, you will need to contact our Customer Support Center. The contact information is listed at the bottom of the service advisory.
