Dust inside RF 24-105
CORNED1
I've got dust inside the front glass of this lens. When I checked out the Canon website, I see lens cleaning, but that only applies to the outside of the lens. No other option was shown. Is there a way to request inside cleaning? AND, after reading some the posts, is that too risky? It sounds like they have some reliability problems with re-assembly. How common is that?
6 REPLIES 6
March411
Your best bet is to give Canon customer service a call, the support staff does a real nice job of assisting with repairs. I haven't used them much but each time they were flawless and resolved my issue immediately.
800-385-2155 or 800-652-2666
Marc
Windy City
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Tronhard
VIP
VIP
Dust in a lens is almost inevitable over time, the physics of an extending lens mean that air has to pass through the lens as it extends (bellows effect) which can take microparticles with it, and they can be attracted to each other .  However, that should not have an impact on your images, as it is well within the minimum focal distance.  Lensrentals.com actually found a whole fly inside one of their lenses without impacting on the image - Lens Rentals | Blog The article also traces the disassembly of the lens and thus why sending your lens in to remove dust is not a small venture and will likely cost a packet.
What will be seen will be dust on your sensor - that will show up  as dark spots.
cheers, TREVOR
Thank you.
That puts it in perspective. I have cleaned the sensor and, of course, I keep the outside of the lenses clean. It just bothered me to see something inside I couldn't get to.
It's nothing you can really control but just mitigate where possible by good camera hygiene - which you seem to be following - it's just physics at work! 🙂
cheers, TREVOR
ebiggs1
It's nothing you can really control ..." "... that should not have an impact on your images,..."
You bet, a few dust particles aren't going to affect the photos. I once had a lens with a cracked front element but the photos didn't come out nearly as bad as the crack looked. You see these artifacts are basically out of focus so the camera doesn't see them.
EOS 1DX and many lenses.
