Difference Between RF24-50mm and RF24mm Macro
JARLYT
I'm thinking of purchasing one of these Lens.
What's the difference between CANON RF 24-50MM F4.5-6.3 IS STM & Canon - RF 24mm f/1.8 MACRO IS STM Wide Angle Prime Lens?
I'm thinking CANON RF 24-50MM F4.5-6.3 IS STM is better to purchase because it can be adjusted up to 50mm.
14 REPLIES 14
That is a good lens choice for general photography.  I would mostly use it outdoors.  It is designed for full frame [image] sensor cameras, but it will work just as well on an APS-C image sensor camera.
The standard kit lens for the R7, the Canon RF-S 18-150mm f/4.5-6.3 IS STM Lens, is close to being an RF mount equivalent to the EF-S 18-135mm lenses for DSLRs.  If you are looking for a quality general purpose lens for an R7, then this would be a great choice.
JARLYT
Thank you, Waddizzle.
ebiggs1
I would avoid buying the a 50mm prime especially if it is your only lens.. It is a difficult FL to make general use of. So unless you have a specific requirement stick with a zoom. Back in the olden days when zooms were not as good as the primes and nowhere as good as they are today the 50mm was a popular FL. However that was basically do the the fact 50mm is the closest FL to what the human eye sees.
BTW, you can learn DOF from any lens.
EOS 1DX and many lenses.
Thank you.
@jarlyt,
Since this thread has expanded from lens difference to body types, I think it might be worth while to for you to also read this short article on APS-C vs full frame and how the body type or lens choice can influence one another:
APS-C vs full-frame - Canon Europe (canon-europe.com)
