07-03-2023
09:08 AM
08:51 AM
I'm thinking of purchasing one of these Lens.
What's the difference between CANON RF 24-50MM F4.5-6.3 IS STM & Canon - RF 24mm f/1.8 MACRO IS STM Wide Angle Prime Lens?
I'm thinking CANON RF 24-50MM F4.5-6.3 IS STM is better to purchase because it can be adjusted up to 50mm.
07-03-2023 12:57 PM - edited 07-04-2023 10:03 AM
That is a good lens choice for general photography. I would mostly use it outdoors. It is designed for full frame [image] sensor cameras, but it will work just as well on an APS-C image sensor camera.
The standard kit lens for the R7, the Canon RF-S 18-150mm f/4.5-6.3 IS STM Lens, is close to being an RF mount equivalent to the EF-S 18-135mm lenses for DSLRs. If you are looking for a quality general purpose lens for an R7, then this would be a great choice.
07-03-2023 01:08 PM
Thank you, Waddizzle.
07-04-2023 10:20 AM
I would avoid buying the a 50mm prime especially if it is your only lens.. It is a difficult FL to make general use of. So unless you have a specific requirement stick with a zoom. Back in the olden days when zooms were not as good as the primes and nowhere as good as they are today the 50mm was a popular FL. However that was basically do the the fact 50mm is the closest FL to what the human eye sees.
BTW, you can learn DOF from any lens.
07-05-2023 08:52 AM
Thank you.
07-05-2023 09:44 AM - edited 07-05-2023 09:47 AM
@jarlyt,
Since this thread has expanded from lens difference to body types, I think it might be worth while to for you to also read this short article on APS-C vs full frame and how the body type or lens choice can influence one another:
APS-C vs full-frame - Canon Europe (canon-europe.com)
