12-31-2017 11:21 AM
My 5D Mk3 seems to have a DoF which is biased from the focus point towards the camera. In other words the depth of field is not equal about the point of focus. It is particularly noticable on my Canon 85mm f1.8 lens when taking "close up" photos at about 1m from the camera at wide appatures. To a lesser extent it also seems present on my 24 - 70mm f2.8 and of course the effect is less at longer focus distances and smaller appatures. Has anyone else experienced this and can it be adjusted (or is that normal)?
12-31-2017 12:11 PM
Thanks for your help and patience!
12-31-2017 05:04 PM
@FWG wrote:Excellent - are there any instructions (Canon or otherwise) that can help me [use AFMA to correct my focusing issue]? I do not want to make it worse!
Look it up in your instruction manual. AFMA isn't nearly as complicated as some make it out to be. All you really have to do is take a series of pictures, using different AFMA settings, of a scene that has objects at different distances and zero in on the setting in which the object actually in focus most closely matches what the camera thought was in focus. Your 5D3 allows you to record AFMA values at both ends of a lens's zoom range for greater accuracy.
12-31-2017 06:10 PM
Psst. EF 85mm f/1.8 prime. I disagree. While AFMA adjustments are not complicated, once you have done it a couple of times. Iit is all too easy to take bad test shots the first time you do it.
The hardest part is figuring whether or not you need a positive or a negative adjustment value. I said that it was “back focusing”, while someone else said it was “front focusing”. Which is it?
12-31-2017 07:59 PM
If a +1 adjustment gives you better focus than zero adjustment, it needs positive adjustment. If +2 gives you better focus than +1, it needs more positive adjustment. Etc. Same with negative adjustment. And it doesn't matter if you get it wrong the first time; you just try again.
And you did notice the OP's reference to a 24-70 f/2.8, right?
12-31-2017 08:43 PM - edited 12-31-2017 08:48 PM
"And you did notice the OP's reference to a 24-70 f/2.8, right?"
Yup, I noticed.
"It is particularly noticable on my Canon 85mm f1.8 lens when taking "close up" photos at about 1m from the camera at wide appatures."
His complaint is primarily with the 85mm prime, though, not the zoom.
Is it back or front focusing? I like your answer. You proved my point. It is not quite as simple and straight forward as it might seem. You have to pay close attention to what you're doing. The devil is in the details. Plug and play, doesn't work well.
The OP says the [camera/lens] combo causes the DOF to be between the camera and the subject [plane of focus]. It is back focusing. The camera is focusing behind the actual DOF. You would enter a negative value to compensate. A negative value decreases the distance to the plane of focus, which brings the plane of focus closer to the camera. A positive increase the distance to the plane of focus, which moves it away from the camera.
01-01-2018 06:12 AM
Hi Waddizzle
As you were so helpful re my question just to let you know the outcome. I followed all the tests you suggested and have concluded that I am not a very good photographer as I could find nothing wrong with my camera or lens settings. It is however sometimes good to know what the problem isn't as I can now concentrate on my technique knowing that there is a perfect shot to be had!
Thanks again and Happy 2018
01-01-2018 09:58 AM
Most lenses do not need AFMA. The easiest way to do it is with a ruler. Lay it on the floor about 7 feet (not a fixed value as FL will change this) away. Use center focus point and shoot towards the middle of the ruler. It is easy to see the DOF. Use a wide aperture and longer FL if it is a zoom lens.
01-01-2018 10:26 AM
@ebiggs1 wrote:Most lenses do not need AFMA. The easiest way to do it is with a ruler. Lay it on the floor about 7 feet (not a fixed value as FL will change this) away. Use center focus point and shoot towards the middle of the ruler. It is easy to see the DOF. Use a wide aperture and longer FL if it is a zoom lens.
A ruler works, but it is bit short. I think a yardstick or a tape measure works better, especially with longer focal lengths.
01-01-2018 10:28 AM
@FWG wrote:Hi Waddizzle
You may be better than you think. It takes a good photographer to recognize their flaws. Besides, many consumer grade lenses do not seem to focus consistently enough to bother with using AFMA, not unless they are WAY off the mark. A lens like that would need repair, anyway.
01-01-2018 11:03 AM
"A ruler works, but it is bit short."
Hmmm, I didn't suggest to use a 6in or 12in 'ruler'. But ti does depends on several other factors on what type ruler you use.
