09-25-2024 08:38 PM
Hi Everyone,
Not sure what happened, but whenever I install my EF-M 11-22mm lens into M50 Mark II it continuously beeps, and the screen goes black. It used to work just fine, and only used it a few times. I mainly use the EF-M 22mm lens, and that works perfectly. Any suggestions is greatly apprectiated.
My camera firmware is Ver.1.0.3
My lens firmware is Ver 1.8.0
Thx!
09-28-2024 01:43 PM
oldnebraskadude,
Well, if it's happening with one lens, but not the other, I'd be tempted to say that there's something wrong with your first lens. Have you inspected it to see if any of the pins are bent or out of place? Have you tried cleaning off the contacts to see if there's any dirt particles or anything else that might be interfering with the electrical connection?
If you've done those things, and the problem persists, I'd definitely quit using that lens until you can get it inspected and/or repaired.
Steve Thomas
09-28-2024 02:28 PM
Thanks for your very helpful and detailed response! I can only agree with Steve that your issues seems to be a fault with the lens, which is a pity - I have an M5 and the 11-22 is one of my favourite optics for that. I suggest you contact Canon at 800-OK-CANON to talk to a tech support specialist.
09-29-2024 10:55 AM - edited 09-30-2024 10:20 AM
"... I do know that you are supposed to turn off the camera when you change lenses. "
I never turn off the camera to change lens and I don't know any pro that does. The first contact break turns off electric current to the lens and it is the last contact to make the circuit when installed. So there is no power going to the lens from the camera to moment you start to twist it.
As to dust getting in, I haven't noticed it but always use common sense if you are in a dusty environment. You may need more care than simply turning off the camera. A lot of the guys I used to run with don't even us lens caps or body caps. I always did and do and I suggest everyone use them. My full time photographer niece, my own niece whom I taught, doesn't' use lens caps but I have gotten her to use the camera body cap. She sells her work for a living!
Is it best to turn off the camera and put the gear in a changing bag before switching lenses? Yes it probably is. However is necessary and/ or practicle? Hey this is a case of whatever works for you.
09-29-2024 08:07 PM
Hey EB 🙂 You and the others advice is greatly appreciated! I was dusty contacts that caused the problem. I can’t believe something so simple hadn’t crossed my mind! One gentle wipe of the contacts was all it took, and now everything works like new.
I truly appreciate your help!
Brett 🙂
