02-10-2023 04:36 PM - last edited on 02-11-2023 09:19 AM by Danny
Hi was wondering if anyone with the canon 70-200 have the same problem,When I attach it to my camera you can hear like a motor continuously running in the barrel is this normal….
02-12-2023 11:22 AM
The OP mentioned that when the camera was off the IS was still functioning. This shouldn't happen at all if the camera is off. That's why I was suspicious of the mount adapter a reset probably wouldn't fix the problem. Since the problem is happening when the camera is off. A reset is a good try though.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D & Sigma 17-50mm F/2.8 EX DC OS HSM
02-10-2023 04:57 PM
No this is NOT normal the AF motor and image stabilizer are only active when the camera is powered up. The lens should be 100% silent when the camera is OFF. What camera are you using this lens on. What is the Full name of the lens. Canon has made 4 different EF Mount versions (one without IS the other F/2.8L models have IS) and 1 RF Mount versions of this lens. Are you adapting this to an EOS R series camera.
-Demetrius
02-10-2023 05:00 PM
Yes it’s the 70/200 l is f2.8 ,I use it with my canon r7 with adapter
02-10-2023 05:04 PM
If you have an EF Mount DSLR camera test the lens on that camera to make sure its NOT the lens. You could have a faulty mount adapter. Which mount adapter are you using Canon or a 3rd party adapter. Stick with the 1st party Canon mount adapters.
-Demetrius
02-10-2023 05:27 PM
works fine on my 5d, But when I put on my 7r with adapter goes off when you switch image stabiliser off
02-10-2023 05:36 PM
So your saying that the lens functions correctly with the IS turned OFF. The mount adapter is likely faulty then.
-Demetrius
02-10-2023 05:40 PM
Will get new adapter,Thank you for your help…
02-10-2023 05:46 PM
If the mount adapter was purchased recently it can be exchanged or sent to Canon for repair.
-Demetrius
02-12-2023 11:14 AM
"If the mount adapter was purchased recently it can be exchanged or sent to Canon for repair."
Hold on there cowboy! Not so fast. First let's do a simple reset of the R7. Get it back to factory default. Menus>Tools>Clear all settings and Clear all custom settings. Now try the lens/adapter combo out. If it still shows improper behavior call Caon 1 (800) 652-2666.
Returning the adapter just to get another one that shows the same behavior won't help. Do the reset first and call support.
02-12-2023 11:22 AM
-Demetrius
