Canon 17-40mm Lens Photos Looks Flushed
jahlavay
I bought a used Canon EOS-1D Mark IV along with a Canon 17-40mm wide-angle zoom. When I use the lens, the picture is extremely flushed, too much light. But when I use the standard 50mm lens that also came with the camera the photos look good.
Is there a setting for the 17-40mm that I need to make?
11 REPLIES 11
Based on your very minimal post, it's impossible to know what the problem is; or even how much you know about photography.  I'm going to start by assuming you're a complete beginner; if this is too insulting, well, you need to post more info.
When taking pictures, it's up to you to control the exposure; i.e. how much light hits the sensor during the exposure.  You can do this by controlling the aperture and shutter speed.  You can also control the sensor's sensitivity to light, which is called the ISO.
You can do this by putting the camera into aperture or shutter priority mode, or you can use a program mode.  In any of these modes, the camera will make its best guess to get the exposure right.  But it can easily be misled by different scenes; for example a photo of a snow scene may come out too dark.  So you need to know how to compensate for this to get good exposure.  You can also use manual mode, where you control everything directly.
If you're not already comfortable with this, there are many resources online which can teach you the basics of photography.
If you want more help from this forum, I suggest posting *way* more details.  For example, some example pictures, and for each picture:
  • what mode is the camera in
  • what exposure compensation are you using (the "+/-" setting)
  • what are the aperture, shutter speed and ISO
  • what exact lenses are you using ("standard 50mm" isn't nearly enough detail; Canon have made many 50mm lenses: https://en.wikipedia.org/wiki/Canon_EF_50mm_lens )
Hope this helps.
jrhoffman75
Welcome.
If the camera is exposing properly with the 50mm lens but not with the 17-40mm lens it is possible there is a problem with the zoom lens.
Reset the camera to factory settings, clear all custom functions and then set the camera to Program mode. Take a photo with both lenses outdoors in good light. Report back what happens.
R6 Mark II, M200, Many lenses, Pixma PRO-100, Pixma TR8620a, Lr Classic
Waddizzle
Take a normal photo with the 50mm, and then switch to the 17-40mm without changing any camera settings and take a second photo.  Just take off the prime, and replace it with the zoom.  Repeat these steps a couple of times, capturing 2-3 shots with each lens.
If the prime photos are consistently good, while the zoom photos are consistently poor, then it is almost a certainty that there is an issue with the zoom.  If it is used, return it for a refund.
ebiggs1
The two posts above are good tips. But do the full reset first. Plus a second camera isn't a bad idea either. Test both lenses on a different body.
jahlavay
Thanks for all the comments. After trying numerous times and reset to the default settings and using the "P" mode, nothing helped. By moving the mode to Shutter Priority, I was able to get some good photos with the 17-40 zoom
Can you post a file from both P mode shooting and Av mode shooting to a file sharing site like Dropbox or One Drive. Preferably a RAW file, but JPEG if that is all you are shooting.
jahlavay
17-40mm Zoom17-40mm Zoom50mm50mm17-40mm Zoom17-40mm Zoom50mm50mm
jahlavay
I uploaded 4 pictures: 2 made with the 50mm lens and the other 2 using the 17-40mm zoom lens. All were taken on the "P" mode and AF focus setting. You can clearly see the "flushed" photos using the 17-40mm lens. As I mentioned before, when I use "shutter priority" instead of "P" mode, I can get the zoom lens to take a good photo.
Just speculating. If the 17-40 works in Tv but not in Av, then maybe the camera is not able to change the aperture on the lens. This might be an easier test.
