Canon 100-400mm f/4.5-5.6 L IS USM (First Version) Camera Display Jitter/flutter
bob31411
I looked around a bit and did not see an issue mentioned that looked like what I am seeing. I have a new-to-me Canon 100-400mm f/4.5-5.6 L IS USM Lens. I have tried this lens on my 3 different bodies - 6D, 5D Mark II, and 5D Mark III. I am seeing the same issue intermittently on all three bodies.
Here is a link to a video that I shot with my cell phone through the lens of one of the bodies. 5D Mark III, I believe.
https://drive.google.com/file/d/10XA9vFI4harCC9T-68nwtKxsmKrXX8db/view?usp=sharing
I can only describe it as flutter or jitter. When I press the shutter release button down, sometimes it will just flutter and not allow a picture to be taken. Happens on all three bodies. I can release the button and press it again and generally it will autofocus and take a picture. I thought it might be an IS issue, so I changed modes - no difference, I switched IS off and no difference. The problem has seemed to have gotten better with usage of the lens.
Anybody seen anything like this. I have also tried single shot, AI Servo, and AI Focus modes. No difference.
My gut feel is that it might be a setting, but since it happens on all three bodies, it has me perplexed.
Regards. Bobby
Anonymous
Not applicable
It looks to me like the lens will need to be repaired. That is a hardware issue with the lens.
8 REPLIES 8
deebatman316
Are you recording video or just stills. Older USM will jitter or snap back and forth in video mode. This can't be changed since the lens doesn't have the hardware. For smooth focus transitioning like newer lenses have. Are you using live view or viewfinder. What happens when you switch from AF to MF on the lens. That looks like an IS issue from the video. You shouldn't see anytime of "jump" of the image in the viewfinder.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Anonymous
Not applicable
Too bad this is a v1 lens.  Canon released a FW for something which appears to be similar on the MKII.   Unfortunately your MKI will need to go to Canon for service.
For MKII only
File Version: 1.0.7
File Size
4.27 MB
File Languages
English | Spanish | French | Japanese | Chinese
Post Date
11/05/2020
Download and Installation Instructions
Firmware Version 1.0.7 incorporates the following fix.
Fixes a phenomenon, in rare cases, the IS mechanism may cause the image to jump.
Thank you for your reply. Stills only. Viewfinder only. I will try switching from AF to MF. Should have tried that. The VERY odd thing is that the more I use the lens, the less frequent it exhibits the issue. Could it have not been used for a while and using it is helping it? I don't know.
Regards. Bobby
bob31411
Ooops, I accidentally hit "Accept As Solution" instead of "Reply" on one of the comments. Darn it.
What I have noticed is that the more I use the lens, the issue seems to be happening less and less. Not sure what that means. I still have a window of opportunity to return the lens.
Regards. Bobby
Anonymous
Not applicable
I would return it, it shouldn't do that.
No the lens needs repair. That looks like a problem with the lens IS motors. Only early EOS film bodies. You would see a shaky image in the viewfinder. That IS normal for those cameras. But none of Canon's DSLRs exhibit this behavior at all.
-Demetrius
Agree with Bob.  The jitter (jumping) behavior appears to be malfunctioning IS.  There will be another lens and another deal, but it won't have the jitter issue.
