Advice for using camera gear on the beach
nehhet
So I’m going to an event this weekend called The race of gentleman. Should I expose my camera to the elements. I plan on only keeping my rf100-500 on my r6 mii and not changing the lens. Should I use a cheaper lens like my 24-105 f4 or don’t bring a camera at all. It’s supposed to be sunny and mid 70’s I’ve shot by the water plenty of times but never a prolonged amount of time like this. Maybe 3-4 hrs.
5 REPLIES 5
Only you can answer this question.  I'm usually cautious and avoid lens changes in unfriendly conditions where possible..  If there's no wind and it's going to be still, it's not a big deal shooting at the beach.  I've had my camera to the beach many times with no ill effects.  If it's windy enough to blow sand around, I won't do it.  If I was going to be around people playing volleyball I would do so from a distance.  Sea spray is the same. You can be near the water and take photos safely.  I also gently wipe down my camera every night after it's been used.  So it is stored clean ready for its next adventure.  If you have to apply sunscreen, bring wet wipes for your hands.  They are also helpful for food if you don't have a place to wash your hands.  Taking reasonable precautions goes a long way.
Sand and playa dust are two things you will never get out of your camera.  If you are in doubt, you can always use a mobile device.  If you do notice sand or foreign debris, Canon offers cleaning and maintenance services.  I'm not telling you not to bring your camera to the beach.  A camera is made to be used, so again just be mindful of the conditions.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
ebiggs1
Camera gear is made to use. If you can't use it or are afraid to use it what the heck good is it? My gear does what I want or I get something that will.
I have shot beach scenes while standing in the Atlantic ocean water up to my waist. I have shot in the desert southwest and the frozen north. The gear goes with me but of course it is wise to use some common sense, too.
However now in my advanced age I consider whether I can stand the environment or conditions and if that is a yes, then the camera gear can. 😁
Tronhard
VIP
VIP
As my colleague Ernie said, you have to manage risk and use your gear.  The R6 series has decent weather sealing as do both the RF lenses you mention, but they do extend, so air will move through those lenses towards the camera.
Really, the wind is going to be your worst enemy.  If it's windy, and blowing from the sea, that will blow both sand and salt air a considerable distance inland.  Even if it's blowing off-shore, you may get sand coming the other way.
The following image shows the salt and sand laden air blowing way inland
For me, this is where I would definitely use a good quality front protect filter: for environmental threats such as airborne particles, that is the filter's forté.  It seems to aid in the reduction of air ingress via the front element, as some Canon lenses specify that such a filter is required for weather protection.
As to the rest of the camera, if in doubt, as simple a thing as a plastic bag even an bread bag (sans bread! 😊) with a hole cut for the front for the lens at the (normally) closed end of the bag, and the open end to your face would mostly protect from other particles, especially coming in via lens extension.
If you are hefting the body and lens for a considerable time, I would take a camera bag or holster and have the camera in that - removing it only when you absolutely need it and, as I am sure you are aware, avoid changing lenses in open air - if I have had to I used a very large plastic bag which could fit both lenses and the camera on he one occasion I was stuck at a beach and had to change optics.  Also, turn the camera off if changing lenses - that will stop the sensor being energized and thus attracting dust and also the shutter will close in front of the sensor.
As Rick said, make sure you have clean hands, so water-based wet wipes and a dry cloth would be a good idea. For hydration, I take water and avoid sticky drinks.  Definitely, going through a thorough cleaning process afterwards is a wise precaution.  I often have a very small paint brush to dust off the body from time to time in dubious conditions.
cheers, TREVOR
zakslm
Rising Star
Rising Star
nehhet,
I agree with the all of the advice you've been given, particularly Ernie's advice, "Camera gear is made to use. If you can't use it or are afraid to use it what the heck good is it?"  Not doing so with stuff and things is what my wife calls "pickling" which I am sometimes accused of doing.
About 1.5 yrs ago, I did a fair amount of beach shooting in Hawaii (Kauai).  I've also done some shooting at beaches when visiting SoCal.
I was careful about salt spray from the ocean and the cautious about sand and windblown sand and I didn't have any problems.  I always have a protective filter on my lenses and they come in handy on the beach.
I won't repeat Rick, Ernie and Trevor's other advice and tips, but they are worth following.
As for clean up, as soon as I could after leaving the beach, I did clean my gear whether it looked like it needed it or not including the filters on the front of my lenses with a brush and microfiber lens cleaning cloth and the exposed surfaces of the camera and len barrel with a clean, inexpensive microfiber cleaning cloth like those used for household/auto cleaning tasks.  Sometimes I moisten a corner area of that microfiber cleaning cloth ever so slightly with fresh clean water and go over the plastic surfaces of the camera.  I try not to moisten it very much so that when the slightly damp cleaning cloth is rubbed over the plastic surfaces, any moisture on the camera seems to evaporate immediately.
Good luck!
LZ
ebiggs1
"Not doing so with stuff and things is what my wife calls "pickling" which I am sometimes accused of doing."
Avatar
