06-05-2016 07:43 PM - edited 06-05-2016 07:44 PM
I recently upgraded from a prime 400 5.6 to the 100-400 4.5-5.6. Many of my shots have a bokeh with parallel lines in it. Trying to figure out why. I have a UV filter on, not a polarizer, which was my first thought. I have not tried without a filter yet, but will. Thought maybe someone here might have an idea why I'm getting this. The other thing I have noticed is that the autofocus is not as fast as with the prime and sometimes struggles to get to focus. I'm a bird photographer, so sometimes my subject is quite small and in a bunch of branches, but my prime was faster. I still like the final photo result of the new lens better, so I'm sticking with it. I attached an example of the bokeh problem
06-11-2016 09:25 PM
Great pictures are made in post, not in the camera. Usually, that is. You need to and if you don't learn PS and/or LR you can probably forget great bird photos.
Don't kid yourself, a lot or even most all great bird shots are cropped.
BTW, that servo motor harmonics thing, whatever, is more likely just a good theory. Nothing more. Ditch the filter and learn how to post edit.
06-11-2016 09:29 PM
Also forgot to mention, your sandpiper is real nice. That's what you'er after. Keep doing it.
06-11-2016 09:39 PM
I give up. I took a few hundred pictures the same day I shot the robin. There seems to be no rhyme or reason as to why a handful of shots show the parallel line bokeh. I can only speculate.
Here's a shot with same shutter speed, and exposure. EXIF says AI Servo was active, but the crow was motionless.
The only variable that is changing is AF mode, and whether or not AI Servo is actively tracking. Remember, I'm using BBF. In the above shot, the bird was grubbing for worms, so I grabbed a focus in AI Servo and kept it active. Thanks, to the Show Focus Points plug-in for Lightroom, I can tell whether or not AI Servo is active or not.
When AI Servo is active, then the "red+black" focus point is displayed. When I release the BBF button, then the "red+white" focus point is displayed. This shot, and the robin shot, are both reported with a "red+black" focus point. In DPP4 there is also a way to tell when AI Servo is active, too. Curiously enough, when you look at the EXIF data of shots when the BBF button has been released, but after focus has been locked on something, then no AFMA data is recorded, which corresponds to the first scenario shown above, "red+white".
I cropped it as close to 1:1 as I could. Clean bokeh, without any lines. Same filter, lens, camera, photographer, exposure, BUT, it is a different bird. I NEVER see the distortion when I've released the BBF button, which does not mean that I will always see it when AI Servo is active. And, I never see the distortion when AI Servo seems to have nailed the focus, either.
That's all for now, folks. I'll start a new thread on this, if I have anything conclusive to add.
06-11-2016 09:49 PM
Not sure about your guesses as to what's wrong, but that bird is not a crow! It is a common starling.
06-11-2016 09:58 PM
"BTW, that servo motor harmonics thing, whatever, is more likely just a good theory. Nothing more. Ditch the filter and learn how to post edit."
"Good theory?" That's a compliment. I consider it to be a wild guess, just a blind shot in the dark.
The use of a UV filter seems to make no difference. I've seen it both with and without. For me, it just seems to appear at certain shutter speeds in AI Servo mode. It could also be the IS at work. I haven't figured out a way to rule out the Image Stabilization, not short of turning it off, because there is nothing in the EXIF data that reports the state of the lens in that detail.
06-11-2016 10:05 PM
@ebiggs1 wrote:Not sure about your guesses as to what's wrong, but that bird is not a crow! It is a common starling.
Crow? That was another guess. Too lazy to look it up, really. It seemed to be too small to be a crow.
06-11-2016 10:17 PM
Crows have black bills.
Your investigation of the bokeh problem is interesting to say the least. i don't think the IS is the culprit, however. if it is, it must be unique to the 100-400.
06-12-2016 06:54 AM
@ebiggs1 wrote:Crows have black bills.
Black bills, you say? I have no idea what type of birds they are. I know crows were in the area, because I could hear the distinctive "caw caw" of crows in the trees. All I know for certain is that these birds are ugly and aggressive, but smallish.
I don't know what to think about the bokeh. It shows up in the 150-600, too, but randomly scattered line segments, not parallel lines. I;m not using sleep over it. I'm gonna blame stray nuetrinos. Case closed.
06-12-2016 09:49 AM
"Black bills, you say? "
Yes, Crows have black bills. The second bird is still a Common Starling. They have black bills in winter. It turns yellow in the summer. It is not uncommon for birds to change colors of some parts with the season. Starlings can mimic other bird's call. too. They are considered a nuisance bird by most people.
06-12-2016 09:54 AM
But the bokeh lines thing. I think it is well known that the 100-400 doesn't do well with any filter. My guess it is the filter or perhaps a combination of things. Filter, exposure + editing, etc.
I have never seen it in my shots.
"It shows up in the 150-600 ..." It hasn't in mine and I have both versions, or I mean all versions. But I haven't tried to duplicate it.
