12-16-2014 02:58 PM
Which is a better overall lens the Canon EF 70-300mm f/4-5.6 IS USM Lens or the Canon EF 70-200mm f/4L USM Lens?
12-16-2014 04:28 PM
Between 70 and 200 mm the 70-200 is the better lens, providing you don't need image stabilization. But if you need IS or longer than 200mm then obviously the 70-300 is a better call (I'm assuming you're referring to the non-L version - the black one, not the white).
Personally, I'd recommend the 70-200, but it's not universally better. It depends on your needs:
70-200
70-300
Longer Range
Image Stabilization
12-16-2014 05:07 PM
12-16-2014 05:41 PM - edited 12-16-2014 05:55 PM
12-16-2014 05:55 PM
12-16-2014 06:09 PM
Hard to say on IS. I tend to push the limit a lot on shutter speed, so I like IS. Although I shoot with primes a lot that don't have them, so I get by. It really depends on what type of photography you do. These lenses are very popular with sports and action photographers, where you typically need fast shutter speeds to keep up with fast subjects. In that situation IS doesn't really do much.
There is an IS version of the 70-200 f/4, though it cost significantly more. Note that the optics are even higher regarded than those in the non-IS version. Canon is out of stock right now, but you could pick up a refurbished version for $880:
12-16-2014 06:51 PM
12-17-2014 10:13 AM
IMHO, I think the difference is significant. The 70-200mm f4 in any of it's forms is worlds better than the 70-300mm (the black one).
In the first place the 70-200mm is a full on pro level lens with all the featuers that brings like weather sealing and non-comparable build quality. Not to mention the 70-300mm if esentially a stop slower at f5.6.
Remember IS improves you. It does not improve the lens.
12-17-2014 11:45 AM
True. Thank you.
