Auto Focus Microadjustment - 5D III
Eaglewing
I am about to experiemnt with AFMA on my 24-70mm L f/2.8. I read from the manual that I need to adjust the wide end as well as the telescopic end separately.
Can anyone who has made similar adjustments please advise at what distance should this be carried out.
I read from various sites that the recommended distance is to multiply focal length with 50. So for the wide end, it will be 1.2m (50 x 24mm) and 3.5m (50 x 70mm) for the telescopic end.
And for the 70-200mm zoom, it will be 10m for the telescopic end (50 x 200mm). I plan to check out focus accuracy for this lens too.
I am also making a DIY GhettoCAL which I printed from the internet as against purchasing the DataColor SpyderLENSCAL.
This post is all about the question of using the correct distance when doing a focus test.
Thank you in advance.
Edwin Ho - Perth, Western Australia
5D, 5D III, EF 24-70mm f/2.8L, EF 70-200mm f/2.8L IS II, EF 40mm f/2.8 STM, 580 EX II
Lightroom 6, Photoshop Elements 10
And others.
25 REPLIES 25
diverhank
Yes the recommended distance is 50 times the focal length...so you would do 2 sets of calibration, 1 for the wide end at 24mm and another for the 70mm.  You enter the two numbers in and the camera will interpolate for the FL in between.  I usually use the actual distance that I shoot with the most.
One word of caution is that lighting condition (even the kind of light) as well as intensity of light will greatly affect the camera focusing system and therefore affecting your AFMA numbers so it is important for you to calibrate using the lighting condition that you will most often use.  For this reason, in the camera manual, Canon recommends calibrating before a shoot
Even though you didn't ask, I'd offer a good AFMA method called Dottune.  This is a very good and fairly simple method of AFMA.  You will need a very good, high contrast target for focusing.
https://www.youtube.com/watch?v=7zE50jCUPhM
http://www.testcams.com/DotTune/CrossHatch_Target.png
Diverhank's photos on Flickr
There's no reason you shouldn't give it a try. But I've yet to see an "L" lens that needed AFMA.
Bob
The lenses that I've bought from the Big Blue Box store are terrible.  I've had to return them.  The issues I had with a 70-200mm having a loose fit came from there.  It was in stock at the store.  I've since realized that the first 70-200 lens had a loose fit because was missing the rubber ring, for weather sealing, around the lens mount. The lens I finally wound keeping had a slight front focus issue.
The BB stores seem to have quality control or security issues.  They seem to have no reservations with selling returned lenses as if they were fresh from the factory.  I have scratched that vendor off of my list of places to shop.  I've had issues with other types of gear purchased from there, too, not just camera lenses.
As far as AFMA goes, I get the best results when calibration is performed more than once, and an average adjustment value calculated.  The Dot-Tune procedure advises you to initially manually focus the lenses to determiine a range of focus.  The entire procedure is conducted by manually focusing the lens, which raises some questions.
Be aware that the cameras record AFMA adjustment information in the EXIF data.  However, no AFMA infoormation is recorded when the lens is in MF, which makes me doubt if any adjustments are made during the calibration procedure, are actually carried out with focus adjustments.  Numbers can be entered into the camera, but it seems that no focus adjustments are made if the camera and lens are NOT in an AF mode, which actually makes sense.  Why should the camera apply a microadjustment when the lens is being manually focused.  Yet, Dot-Tune seems to assume and rely on the fact that focus adjustments are applied in MF mode.
ebiggs1
"But I've yet to see an "L" lens that needed AFMA."
This is my findings also.  If I had one or two "L" lenses I would not make such a statement. But I have actually had the opportunity to use many.
It is possible to really screw things up but it is easy to set it back to O so why not go for it?  Most of the time people that think the lens needs focus adjustment are using the gear wrong.  Or simply have poor technique.  Make sure that isn't you!
EOS 1DX and many lenses.
Hi Diverhank,
Thanks for confirming 50x FL focus distance. I shall stay with this method for now as I do not have a "usual" distance that shoot with. Will give it a try once I have completed building the DIY GhettoCal; almost there.
I may not even have a AF problem to begin with but it is nice to have some sort of confirmaition that the lens is focussing correctly.
BTW I should take delivery of a new Sigma 35mm 1.4 DG HSM Art next week; looking forward to that. The Canon version is way over my budget, hence the Sigma and I have noted pretty good reviews.
The DotTune method seems complicating; but I shall get my head around it.
And others.
Thanks Bob, it is good to know. I don't think I have a problem but it is good to be able to confirm that the lens is focussing accurately.
And others.
Thanks Waddizle for your input.
Honestly, I find Dot-Tune quite complicating and I shall leave it for now until I am able to get my head around it.
And since Canon has provided AFMA in the 5D III, I shall give it try.
I will also be taking delivery of the Sigma 35mm 1.4 together with the USB Dock next week; will see how it all pans out in terms of AFMA.
And others.
Thanks ebigg1,
I am with you on the same page with regards to mis-focus which might have been the result of poor technique on my part. Hence the need to establish first of all the the lens is focussing accurately as it shoul be.
And others.
Edwin, Canon gives you the option to enter your adjustment numbers in the camera but NOT how to obtain the numbers.  You still need to do that yourself.  Dottune is actually the easiest method which takes the guess work out of the procedure.  Most common method is to focus on a point on say a ruler and look at the picture and see where the focus point actually is.  If it is to the back or front of that point then you'd enter in a value to try to get the focus point to be where you'd aimed at.  Problem with this method is it's hard to see your focus point at the 50x distances.
As some have discussed, you shouldn't need AFMA on a 24-70mm L lens.  I did them on mine just for fun and got 0/0 (no adjustment).   For critically shallow depth of field kind of lenses like my 100mm f/2.8L IS Macro or my 85 f/1.2L II...For the 100mm, I needed adjustment of -1 and  that made a huge difference at 1:1.  Similarly, for the 85mm, I needed adjustment of +2 and that made huge difference in sharpness at f/1.2
