Adapting Helios 44M vintage lens to Canon R50
RomMarks
I recently bought the Helios 44M model from 1976 to use on my R50, I would like to ask what is the best to chose adapter considering flange depth of the lens and to not lose infinity focus on it while using.
Can I go for this one screw mount:
 Or this type of more deeper mount:
 Lens have a 45.5mm Flange focal distance (not sure if this enough info for someone to help me)
Thanks in advance
p4pictures
With the flange distance of the EOS R series being 20mm, then you will need the deeper mount so that the Helios  lens is positioned the correct distance from the sensor to allow infinity focus. The mount will need to be 25.5mm thick.
Brian
13 REPLIES 13
p4pictures
Brian
Thank you so much for your help, Brian.
Take care
justadude
Whiz
Whiz
This doesn't answer your question (because Brian already answered).  I just want to say to have fun with the Helios 44M lens!  Which version did you get?  I have the 44M-4.  It is one of my favorite vintage lenses to use on any of my digital cameras, as well as to use when I shoot film.
Gary
Lake Michigan Area MI
Digital Cameras: Canon EOS R6 Mk ll, EOS R8, EOS RP, ...and a few other brands
Film Cameras: Mostly Pentax, Kodak, and Zenit... and still heavily used
Thanks for answering aswell Gary! I got the 44M (no more nrs) from 1976 KMZ made, in amazing shape along with the Zenit camera, all for €50 in my own country Portugal, so no shipping etc.
Realy looking forward to it, I still do not have it with me! Looking to do photos and vídeos with it on my R50!
Any thoughts you can share?
Take care
justadude
Whiz
Whiz
Once you get the lens, look at the numbers on the barrel.  They all have a number following the 44M... -2 and -4 are the best versions, then the -6 and above loose just a little of the dreamy bokeh effects, but not by much.
The swirly bone effects of this lens are fantastic!  Don't be afraid to shoot with the aperture wide open.  If you are not used to manual focus, just practice, practice, practice, and don't give up.  It soon becomes second nature, and is well worth it.
Gary
Mine is the first, no nrs Gary
 Great photos!!
justadude
Whiz
Whiz
That's the first I've seen without the additional number.  Well, your year can't be correct if this was among the first.  They started making these in 1958.
So I forgot to ask... which Zenit camera did you get?  I have the 12XP which is built like a tank, and a lot of fun to shoot.
Gary
Here is something that will teach you alot more about them, then you will understand  why I bought the 44M
Helios Swirls
Especialy this one: Diferences in Fabrication
I bought the Zenit-E along with the lens.
Enjoy, Gary!
Gary, the first two numbers of the serial nr is the year of fabrication (check yours), that symbol with the arrow shows it was made on the Valday factory, less quality fabrication because they were mass produced there. Still quality image of course!
Rom.
