06-19-2025
02:17 PM
03:07 PM
StevenMOD
My 24-70 lens just began giving me an error code telling me that there is no communications between the lens and camera to clean the connection points on the lens. I've done this several times and it may take one picture and then go back to the same message. I have used other lens on the camera and they work just fine so I believe it is something with this lens. Any suggestions?
06-19-2025 03:05 PM
If it is EF it may be the flex cable.
06-19-2025 03:18 PM
It is an EF. If it is the flex cable can that be repaired?
06-19-2025 03:27 PM
Is this the original or the version II EF model. If it’s the original then it cannot be repaired by Canon anymore. The original 24-70mm had flex cable issues. It’s out of service life also what camera do you have.
06-19-2025 03:35 PM
It is the version II and I use it with my Canon 6D Mark II
06-19-2025 03:41 PM
Does this lens work correctly on a different camera. The flex cable could’ve failed if it still won’t communicate with another camera. I believe Canon still services the version II EF model. I would contact Canon to see if they do. If so get a quote first before making repairs.
06-19-2025 03:44 PM
I do get the same message with my 7D. I will contact Canon. Thank you so much for the help.
06-20-2025 10:37 AM
Call Canon 1 (800) 652-2666
