09-13-2016 01:44 AM
Hello all,
my name is Theo. I am not much into photography but i do use a canon 450d with a canon kit lens 18-55mm that is very much useful for shooting eyewear for my online shops.
This is my second kit lens 18-55mm which has malfuctioned. Both lenses that i had been using after 1-2 years of use, stopped autofocusing.
The reason why i am happy with these lenses is that i do have the close up focusing distance that i need which is approximately 0.25m. These lenses have macro capabilities at 0.25m(0.8ft) The range is also very useful and i do not need any longer focal length.
Is there any alternative lens which i could use which is more durable? If yes can you please recommend a few?
Or i should purchase a third one and hope that it will last longer?
Any suggestions are more than welcome.
Thank you for your time.
Theo
09-13-2016 08:27 AM
theocy wrote:Hello all,
Theo
EF-S 17-55mm f/2.8 IS
EF-S 60mm f/2.8 macro
The 17-55 is so big that it casts a shadow in the coverage field of the built-in flash. But for the kind of work you're doing, you probably don't use the built-in flash anyway.
09-13-2016 11:24 AM - edited 09-13-2016 11:24 AM
Theo,
There probably isn't anything wrong with you lens(es). Well there is but not the AF. ![]()
Try this:
I am a fan of the Canon EF-S 17-55mm f/2.8 IS USM Lens. You can't go wrong with it. A better choice might be the Sigma 18-35mm f/1.8 DC HSM Art Lens for Canon. A really nice lens.
I would not recommend the Canon EF-S 60mm f/2.8 Macro USM Lens for you.
09-13-2016 11:33 AM
Dear ebiggs1,
thank you very much for your answers. I have tried your tip but unfortunately it will not help.
It seems i will have to consider EF-S 17-55mm f/2.8 IS USM Lens
09-13-2016 11:34 AM
Dear Bob,
thank you very much for getting back to me.
I will take your advice and i will invest into the EF-S 17-55mm f/2.8 lens. I do not need a flash.
Your answers are very much appreciated.
Thank you again.
Theo
09-13-2016 11:54 AM
"I will take your advice and i will invest into the EF-S 17-55mm f/2.8 lens. I do not need a flash."
I think you're making a good choice. Don't rule out an actual macro lens at a future date, though. They're amazingly sharp.
