07-19-2018 11:18 AM
07-21-2018 11:45 AM
@jrhoffman75 wrote:http://www.learn.usa.canon.com/resources/blogs/2014/20140225_winston_IS_blog.shtml
"Another forgotten I.S. advantageImage Stabilization isn’t just a benefit at slow shutter speeds when hand-holding, however. It can actually make your AI Servo AF better — even at the fastest shutter speeds.
I’ll switch gears and look back at another shot taken with an EF Extender, in this case, using the superb EF 200mm f/2.0L IS lens and an EF 1.4x III Extender at a hockey game. Effectively, this hand-held combination is a 280mm f/2.8 lens, shot wide-open in available light. In action situations, Image Stabilization provides a much more stable view in the finder, even when rapidly moving the camera to follow an erratically moving subject. But beyond that — and many sports photographers don’t think of this — if I.S. is active, the autofocus sensor gets the same stable, clear view of the subject that you would through the viewfinder. Whether working hand-held, as I was in this shot, or from a monopod, the AF system gets a better look at the subject and has an advantage in reading detail and reacting instantly to it during a high-speed, continuous shooting sequence. The benefit? Even greater likelihood of consistently sharp frames, throughout a sequence."
Great point you have made. But in our action case, I think you're assuming that the AF system gets a better look at the subject. I'd say not when it gets confused. We are saying that when you're panning ̣(meaning deliberate movement), in mode 1 and 3, the IS is trying to cancel that panning movement to deleterious effect. Even in mode 2...who can pan perfectly laterally anyways. Canon does a great job compared to Tamron and Sigma but when you pan after a bird, you're better off without IS. Tamron says it in bold print to turn IS off when you do this. On the Tamron 150-600mm, Tamron came out with a firmware to automatically turn off IS when it detects panning. I suspect Canon also does this without telling us.
07-22-2018 10:29 AM
@diverhank wrote:
@jrhoffman75Great point you have made. But in our action case, I think you're assuming that the AF system gets a better look at the subject. I'd say not when it gets confused. We are saying that when you're panning ̣(meaning deliberate movement), in mode 1 and 3, the IS is trying to cancel that panning movement to deleterious effect. Even in mode 2...who can pan perfectly laterally anyways.
Confused as in lost focus on the subject?
That effect you refer to is what I refer to as AF and IS, the AF in the camera and the IS in the lens, getting into a tug-of-war.
