mx922 scan error 2,157,50
bbqyoung
My scanner used to work till yesterday.  Now when I try to scan, document is on the scanner, click scan from the cannon quick menu (as before), and it wakes up the printer/scanner, and seems to start scanning.  Then after several long minutes (longer than before), it gives me the error:  2,157,50.
I've restarted the printer several times, restarted the PC (OS- MS Vista), and restarted the network.
The printer prints fine, both airprint from iOS devices and the PC.
The scanner doesn't seem to work.
26 REPLIES 26
To avoid having to turn on/off your firewall every time, go into your firewall settings and allow access to the Canon IJ Print Utility app and the Canon IJ Printer Assistant Tool. You may have to browse to find and add these to your list. Search under OS/Program Files/Canon.
Does not work
duddly
None of this malarkey works
Baloney
Yeah right sure
duddly
Does not solve
Thanks for joining the conversation, duddly!  As this thread is pretty old, it might be best to start a new thread pertaining to your specific printer and the problem you're encountering.  To start a new conversation, click here and then click the red button that says "Start a Conversation."
Hope to help you soon!
Friends and Family
