01-19-2017 09:21 PM
My printer can print from the internet but it does not print any fonts from pc
EX: if i have an ms word file or any other microsoft software and it has any image the pc will print the image nothing else
01-19-2017 09:43 PM
Hi hombreck,
It sounds like the printer needs to run through a cleaning cycle. Check out the following link for step-by-step directions on the process and then how to print a nozzle check to verify if it helped: http://Canon.us/6dwz
Hope this helps!
01-19-2017 09:47 PM
Thank you for the reply but I tried printing from another PC and it worked just fine. I wonder if it is my PC (windows Insider Preview) that is giving me this problem
01-19-2017 09:51 PM
Another thing is that if i have an Excel file where I have borders, it will print the borders but nothing inside the boders
Thank you
01-19-2017 09:52 PM
Thanks for the update!
It's possible the programs you are printing from are using the same working ink when printing, so printing a nozzle check through the steps above is the best way to determine if this is a printer or computer issue. If the nozzle check differs in any way, try running through the cleaning cycle and this should help!
If the nozzle check matches perfectly from the example on the link, just let us know!
01-19-2017 10:00 PM
I did everything all the patterns came out fine but it still does not print
01-20-2017 06:10 AM
Hi hombreck,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
