08-03-2017 11:37 PM
I have been trying to print a reciept from a web page. All I get is blank pages. I tried printing an email and still blank pages. I did a test print to see if my printer head needed cleaning and it was just fine. Printed perfect. Just can't print anything else. Printer comes up with a print preview and it acts likes it's printing but it's blank. HELP!! Thanks in advance
08-04-2017 07:36 AM
Hi Flo,
First, please make sure that the installed ink tanks are correct and full of ink. The correct order is:
CLI-8BK Black
PGI-5 Black
CLI-8Y Yellow
CLI-8M Magenta
CLI-8C Cyan
Although you have already done this, a test of your PIXMA MP830 should be performed. The Nozzle Check pattern shows if each print head nozzle is operating properly. Please perform the following steps to print a Nozzle Check pattern:
1. Load letter-sized plain paper in the auto sheet feeder.
2. Press the <FAX> button.
3. Press the <MENU> button.
4. Press the right arrow to select Maintenance / Settings, then press <OK>.
5. Press <OK> to select Maintenance.
6. Press <OK> to select Nozzle check.
7. Press <OK> to select Yes.
The nozzle check pattern will now print. Please compare your printout with the example that has been attached to the bottom of this post.
Does your test page print correctly?
08-07-2017 12:54 PM
Yes already did that. Prints perfect. The printer is recognized by the laptop and shows up as it usually does. I did have something in the que that I decided to print just to see if it would and it did. It just seems like it's not recognizing the text or something like that.
