01-02-2019 07:04 AM
Hi all... when I print out an image the white borders around the print are uneven... wider on one side and bottom. I am using this printer for the first time. Its all set up to my desired specs. The window on the left that shows the image in the printing frame has uneven borders as well. Here is a screen shot below. I wonder if this can be changed... I've looked everywhere in the settings. Hope someone can help... and thanks in advance.
01-02-2019 12:21 PM
Hi Tiggerrr2018,
If clearing the "Center" check-box and manually entering border dimensions does not resolve the issue, please call us at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST. This way we can troubleshoot this issue in real time.
01-02-2019 09:54 AM
Your screen shot shows a setting for Position and Size. Have you tried clearing the "Center" check-box and manually entering border dimensions for the Top and Left borders? You may have to fudge the measurements slightly to reposition the image in it's "frame".
01-02-2019 12:21 PM
Hi Tiggerrr2018,
01-02-2019 09:12 PM
Gave them a call and a tech helped me to find the solution.. it was in the Photoshop settings... never would have seen this without his help... again thanks for the number!
05-07-2020 06:31 PM
