ip8720 alignment issue only with 6x4 size
encee
When I print the photo on other paper sizes (8x11 & 5x7) - it all prints perfectly centered/aligned. For whatever reason, only the 6x4 is printing out not centered (shifted left). I thought maybe it was the thickness of the paper, so I cut my other paper sizes into a 6x4, but still had the same issue. I've tried messing with different settings, but nothing seems to work. At a loss as to what might be causing this and how to fix this.
1 REPLY 1
SamanthaW
Moderator
Moderator
Hi!
To have a better understanding of your issue, please let everyone know the operating system on your computer, along with any other info that might be helpful to the community (such as programs you're using etc...).
If this is a time-sensitive matter, please check out your other support options here.
Thanks!
