09-25-2014 08:49 AM
how fix blank lines on scans using MF5770. Already restarted Win 7 computer and MF5770. Using Windows fax and scan. Several months of successful use before this problem began last couple weeks. 9/2014 Thnks for any help
09-28-2014 10:31 PM - edited 09-28-2014 10:31 PM
Hi Chazellepe.
So that we can better assist you, how is the printer connected? Is it connected directly to the computer with a USB cable, or with a LAN cable to a router? If it is connected with a USB cable, how long is the cable, and are there any devices, such as a USB hub or extender, connected between the printer and the computer? Finally, which version of Windows 7 are you running on your computer? Is it the 32-bit or 64-bit version?
We look forward to your reply. Should you need immediate assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
09-30-2014
10:05 AM
10:18 AM
Stephen
Patrice,
Thanks for your reply and questions. See my responses in the body of your text pasted below
So that we can better assist you, how is the printer connected? Is it connected directly to the computer with a USB cable,YES ITS CONNECTED BY A USB CABLE LESS THAN 10' LONG FROM THE BACK OF THE MF 5770 TO A USB PORT ON THE BACK OF MY DESKTOP COMPUTER or with a LAN cable to a router? If it is connected with a USB cable, how long is the cable, and are there any devices,NO DEVICES such as a USB hub or extender, connected between the printer and the computer? Finally, which version of Windows 7 are you running on your computer? Is it the 32-bit or 64-bit version? 64 BIT VERSION SERVICE PACK 1 PROCESSOR AMD PHENOM II X4 810 2.61 GHz INSTALLED MEM 4 GB
Chip Hazel
[Mod note - removed personal information PER FORUM GUIDELINES]
10-01-2014 10:29 PM
Thank you for your reply chazellpe.
To ensure that the issue is not with the scanning unit of the machine, please make a copy and verify if you experience the same issue with blank lines.
If you don't then it indicates that there may be a communication issue between the printer and the computer. Please unplug the USB cable from the computer and the printer. Plug the cable, firmly, back into the printer first, and then plug the USB cable into a different port on the computer. Next, scan a document. If the error persists, it is recommended that you change the USB cable.
If the issue still appears, after changing the USB cable, please contact us at 1-800-OK-CANON for further assistance.
