08-18-2015 04:47 PM
I cannot scan since downloading Windows 10. It says: You don't have the required privileges to access the specified folder Code 9,244,3
08-04-2020 03:19 AM
Hello,
I fixed that problem by changing user rights on profile folder.
I use a french Windows so I'm not sure about english terms.
Canon scan tool couldn't access to "documents" folder so it couldn't create scanned files.
I just added my own account in the security list and gaved it full access.
For security reasons, I just modified "documents" folder (instead of profile folder) that is the default folder used by my scan tool.
So right click on "documents" folder => Properties => Security => Modify => Add => Advanced => Search => Double Click on your own account => Ok => check Full access => Ok
03-22-2021 11:58 AM
I changed my folder as suggested and it worked ONCE
2 weeks later I wanted to scan a document and I got the same old error code
I found that MICROSOFT actually has a scanner for free and you download it and it WORKS
NO MORE FOOLING WITH FOLDERS I guess
it is called the WINDOWS SCANNER
O R
............WINDOWS FAX AND SCAN
anyway it worked at least this time,,, I just hope it keeps on working
03-22-2021 11:59 AM
